Hood Medallion removal and replace - SaabCentral Forums
Old 10th May 2008
mykdee's Avatar
mykdee mykdee is offline
My Saabs: '04 9-5 ARC 2.3T Sedan
Default Hood Medallion removal and replace
Just purchased a new one.
Anyone have any advice on how to remove and replace without mucking the hood up?
Took a quick look and saw there was like a dime size hole under the hood and a "tooth-grip-like washer" holding the one pointed stub from the medallion. Not sure how I can get that off???
Also, any advice on keeping the medallion whole?
Old 10th May 2008
MacNoob's Avatar
MacNoob MacNoob is offline
My Saabs: 01 9-5 Wagon (RIP); 05 9-5 Aero (gone)
Well, mine was just stuck on with two-sided foam tape. It was easy enough to pry off with a thin screwdriver after putting a few layers of tape on the hood to prevent scratches and dents.
Old 10th May 2008
tmg19103 tmg19103 is offline
My Saabs: '03 9-5 Aero Sedan, BLK/Tan
The way to take it off and replace the original is to take blowdryer to it to loosen the adhesive, and then from inside the hood gently hammer it off through the hole with a screwdriver.
The quick, ugly and easy method if you are replacing a worn out emblem is to take a sharp screwdriver or other sharp metal object and hammer it through the center of the top of the emblem and once it is embedded firmly in the emblem, pry it off.
I found prying it from the side, even with tape, to be tough, especially if you don't take a blowdryer to it as it is in an indentation and I was still concerned about scrathing the paint around the emblem.
Old 10th May 2008
luv2drinkcoke's Avatar
luv2drinkcoke luv2drinkcoke is offline
My Saabs: Suzi - 2001 95 Arc 2.3t Auto
Use hairdryer to soften the glue and then i've heard to use dental floss to cut thru the glue. Never tried it, but it was mentioned in this forum.
Old 10th May 2008
Mattlach's Avatar
Mattlach Mattlach is offline
My Saabs: 2009 Volvo S80 T6 AWD
Ive never replaced mine, but as far as keeping it whole, that film stuff they stick on the front of cars these days to protect against stone chips does a good job.
Stateofnines sells precut round slices that stick to the top of the emblem, but they aren't cheap.
2001 Saab 9-5 Aero 5spd manual -> 2004 Saab 9-5 Aero 5spd manual -> 2011 Saab 9-5 Turbo4 Premium 6spd manual -> 2009 Volvo S80 T6 AWD.
I miss all my Saabs
Old 20th May 2008
mykdee's Avatar
Well I purchased the protector and if you ask me, don't bother, it not worth it. After installing it was cloudy and the edges were separating. I was able to take it off and I'm asking for my money back.
Removing the medallion was just as easy as everyone said. Heated up with a blow dryer, used some dental floss and then placed a screw driver in from underneath to pop it off. There was residue from the double stick which needed some extra elbow grease to take off, but other than that it was fine.
Make sure to use iso alcohol to clean off the area to then place the new one on.
Old 21st May 2008
Wrightsfd's Avatar
Wrightsfd Wrightsfd is offline
My Saabs: '08 9-3 Cmbi Aero. '89 900 T'vert 5-spd
do the blowdryer trick. Better yet let the car sit in the sun for a few hours and do it, not much of a problem to do. I shaved the "SAAB" and "95" off the rear this way too, works great.
Just don't let the blowdryer sit in one area too long or you could scorch the paint depending upon how hot a day it is. Just keep it moving in a small circle around the badge for a couple minutes.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
