Front end vibration when accelerating - SaabCentral Forums
Old 4th May 2008
nbsman nbsman is offline
My Saabs: 2000 9-5 ,wagon,manual,almost aero :)
Default Front end vibration when accelerating
I thought i've done with repairs,but i was wrong.
On this week i replaced strut mounts control arms tie rods and ends,did alignment,but have vibration during acceleration the whole front end of the car is shaking not a lot but it's annoying.
Took it to the shop they think that's the inner driver or its bushing in the differential,thesaabsite.com FAQ says the same thing.
Have anybody experienced this issue with their cars?
Old 4th May 2008
99Saabnut's Avatar
99Saabnut 99Saabnut is offline
My Saabs: Currently Saabless
I am currently fighting the same thing. I am pretty sure now it is the driver's side shaft; while I have the car up last night I wiggled the axle and there was about 1/4 inch of play in it.
-Jason
2012 VW Golf TDI
2002 9 HOT Convertible... She will be missed
Old 4th May 2008
earthworm's Avatar
Saab Sage!
Not really, but when the wheel balance was "way off" it was just a proper balance job at Reesers of York Haven..
But, if the axle support bearings are worn, then this will have to be fixed. I have read where there is a process for renewing the bearing without removing the transmission......(maybe this applies to one side ??) - but only at the best indy shop or dealer...
Good luck
The earthworm
'96 900S, Automatic
Old 5th May 2008
redrum's Avatar
redrum redrum is offline
My Saabs: 1997 900SE 2.0t
Inner driver failure is fairly common, if this is the case your cheapest solution is to buy a complete remanufactured driveshaft that includes the innder driver cup.
signature here.
Old 5th May 2008
what about transmission inner bushing ,do i have to replace it as well,what do you think?
Replacing driveshaft doesn't seem like a big deal moneywise.
Old 5th May 2008
redrum's Avatar
A vibrating inner driver may cause the diff bearing to go as well, primarily if its the drivers side.
I got a reman complete driveshaft from Napa a while back for $62+85 core, but recent posts on here suggest that nowhere has them in stock anymore. If one cant be found, the inner driver cup alone is $400ish+ to buy new.
signature here.
Old 22nd October 2008
fivepointnine fivepointnine is offline
My Saabs: 2001 9-3 SE vert. auto JZW 3+
what about the inner driver kits they sell through saabsite.com are they worth it? I replaced my intermediate bearing (carrier bearing) on the passenger side today, it helped but I still have a wobble/vibration on acceleration and am thinking I need to replace the entire passenger side inner driver/tripod bearing assembly.
MaseratiMike's Avatar
MaseratiMike MaseratiMike is offline
My Saabs: 2006 9-3 Aero VTuner Stg 0
I had this problem and it was both an inner driver and diff bearing.
best best is used driveshaft. Tom's Foriegn Auto Parts it the place to go. Diff bushing is ~25 from a dealer.
The saabsite inner driver kits would be fine...if you feel like dropping the couple hundo on it..I wasn't willing to pay that much.
1985 Maserati Biturbo 2.0 Eurospec
1976 Fiat 124 Spyder
2000 Saab 93 SE HOT
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
