How to reset oil change? - SaabCentral Forums
Old 2nd May 2008
miroslav_s miroslav_s is offline
My Saabs: saab 9-3 aero sportsedan
Default How to reset oil change?
Hello, I resently changed oil in my saab 9-3 ss aero ´03 and would like to reset in my SID display oil change sevice to set it on 100% but don´t know how to do it. I tried with the button CLEAR but nothing happens. Can someone please tell me how to do it right. Best regards to you all and thanks in forward.
Old 2nd May 2008
Saab.Racing Saab.Racing is offline
Banned
My Saabs: 2003 Saab 9-3
you can not reset it until it gets to <10% . Then it will bring up an option for you to reset it. I truly hope your not going by that schedule for changing your oil.
Also FYI hit search. I found many threads on this same topic.
Old 2nd May 2008
The Saab Newbie's Avatar
The Saab Newbie The Saab Newbie is offline
My Saabs: 2007 9-3 Aero 6 Speed Manual
You can reset your Oil Life. Just change the date on the SID 1 or 2 years ahead. This will allow you to reset the service indicator.
Jeff
Old 2nd May 2008
sledger's Avatar
sledger sledger is offline
My Saabs: 2004 Saab 9-3 Aero Convertible
http://www.saabcentral.com/forums/sh...ight=resetting
i was just reading other threads and they say changing the date doesn't work.
Old 3rd May 2008
I reset mine just yesterday by using this method. I changed the spark plugs yesterday and also decided since I was at 25% oil life to change that as well. I changed the year to 2010, checked service data and was able to reset it. It is now showing 99% life.
Jeff
Old 3rd May 2008
JonV JonV is offline
Saabista
My Saabs: 03 SE 5 Spd
Which post in that thread says changing the date won't work?
Old 1st January 2009
joebus joebus is offline
New Member
My Saabs: 2005 saab 93 linear
Default saab 9 3 noise
hi i have a 05 saab linear i have noie in front end took to dealer they changed sway bar bushings creaking noise gone but i still hear something in the front that sounds loose sounds like the strut mounts dealer said there fine he told me rear brake pads were replaced and there not saab he said there is some play in the pads thats making that noise i checked pads and they are tight can someone help me
Andy C's Avatar
Andy C Andy C is offline
My Saabs: '04 9³ 2.0t Vector Convertible (BSR St1)
So if I'm reading this right, if I decide to change my own oil (or more likely take it to local garage/Kwik Fit/etc) then I can't reset the oil life indicator until it says 10% or less? How do SAAB techs do it then? And if I change it, have to wait until it says 10% or less, then am I left with it not reading right for the next batch of oil (i.e. it resets to 100% when actual life is say 90%)?
Andy C
2004 Saab 9³ 2.0t Vector Convertible
Mihai's Avatar
Mihai Mihai is offline
My Saabs: '04 9³ Aero
Saab does it using Tech2.
You can do it like this:
Jeff
Saabista
Obviously your not reading it right.....you can set it two ways, after it reaches 10% it will ask you, or you can advance the date.
How do saab techs do it, well if it's under 10% they just push reset when asked, or Plug in a Tech II Programmer.
Old 18th March 2011
Petedoza85 Petedoza85 is offline
My Saabs: 2008 Saab 9-3 2.0t
Garage
Question 08 9-3
I need to change my oil and My display is Saying 5% life left. I can change the oil my self but , How can I rest the display telling me this ? can I ? on this years model
Old 18th March 2011
Nocturne's Avatar
Nocturne Nocturne is offline
My Saabs: 2005 SAAB 9-5 Aero fully loaded
Garage
What does any of that have to do with resetting the Oil life Monitor?
2004 9-3 Linear Fully Loaded - R.I.P July 28 2015
2005 Saab 9-5 Aero Fully loaded
Old 18th March 2011
aerojon's Avatar
aerojon aerojon is offline
absolutely nothing,but the post is 2yrs old & they've not posted since...
Is still running factory oe coils with Hirsch tune..
Old 18th March 2011
Saabista
Start by reading this thread......it's explained a few times.
But again, here is the Short Version, Go into the SID Programming, advance the date a year, exit, go back into Service settings it will ask you if you want to reset, say yes. Exit, go back in and restore the date.
Old 18th March 2011
Aleki's Avatar
Aleki Aleki is offline
My Saabs: 06 9-3 Aero
the only problem I have with advancing the date is the SID counts from the day you reset it at. currently, mine says 365 days, 35% oil life left
40% off orders from
BTW: Its a referral code; Still, I'd greatly appreciate it if you used it on your next order
Old 18th March 2011
Saabista
Using the Oil Life meter is not a necessity.... just use common sense and change your Oil on a regular basis. I have not referred to my OLM for years, I just change Oil every 7.5K. The main Services are mileage based anyway.
When I do reset it just to clear the notice, the % re-sets and counts down but days till service is always 725, never changes.... (03's through 5's are calibrated to two years)
Old 26th July 2011
galanti galanti is offline
My Saabs: '08 9^3SC '94 C900C
Default Reset oil change - Redux
Here's a twist to the thread. The 2008 9^3 Aero SportCombi with navigation allows you to adjust the time but not the day or date so the "set the SID ahead" ploy doesn't work. And the reset button works only when the service needed warning comes on the SID.
I had the oil changed at Falcone Saab yesterday, and when I checked the oil stays today it was at 63%. Somehow I doubt that oil algorithm comes out that the oil shows a 37% degradation in 25 or so miles.
Anyone have any ideas or do I have to take the car back to Falcone?
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
