fault codes , are they available? - SaabCentral Forums
Old 02-05-08
jaggy jaggy is offline
Default fault codes , are they available?
Hi is there any place to get hold of the offical saab fault codes , rather than the generic obd2 codes , i just had a fault code on my 3.0tdi , accordeing to generic obd2 codes its a misfire in cylinder 12 lol only 6 cylinders boys
so are the real saab specific codes available , i am sure our local saab dealer is fed up of me calling!
Old 02-05-08
gghh gghh is offline
My Saabs: BMW 530D Touring xDrive
Faultcodes can be found in the WIS Software.
Old 02-05-08
cbr1100xx cbr1100xx is offline
My Saabs: Saab 95 2.3L Aero Saloon year 2007
There are fault codes, that are specific to the Tech 2 system,
I have WIS, If you have some codes I can look them up for you
Old 02-05-08
toxicavenger's Avatar
toxicavenger toxicavenger is offline
My Saabs: 2006 9-5 Sedan, 2006 Sportcombi
I use this one http://www.canobd2.com/support/DTC_lookup.asp
Old 02-05-08
SaabBlackMan's Avatar
SaabBlackMan SaabBlackMan is offline
My Saabs: 07 9-3 Aero V6
Whats the code your getting, I could look it up and see myself. Cylinder 12? Hmm well maybe you have another invisible 6 cylinders hiddin somewhere.
Saab Blackmista.
Old 02-05-08
Route 17 Route 17 is offline
My Saabs: 2006 9-5 2.3T
In addition to my 2006 9-5 I also have a 2002 Chrysler 300M. I can read the OBD II error code directly off the odometer by using the vehicle Built In Test.
To retrieve OBDII Error codes from your Chrysler/Jeep/Dodge vehicle, do the following sequence with the key: ON-ACC-ON-ACC-ON and look at the odometer, that is where codes will be displayed. Here are the codes that you may/can get.
Then I can look up the error code of the following web page
http://www.allpar.com/fix/computer-codes.html
Too bad that GM and Saab do not have the same.
Old 03-05-08
p1269 is the codes but i had more but erased them , when i change down grear and turn a corner sometimes when i accelerrate the car jolts for a second then goes again no problem i think the other code was p1403 thanks ,
Old 03-05-08
Al's Red Wagon's Avatar
Al's Red Wagon Al's Red Wagon is offline
My Saabs: 1999, Cayenne Red 9-5, 2.3 Wagon
I just looked up you codes and had no luck...It may be a deisel specific problem as my WIS doesn't contain that info...
Old 03-05-08
lol thanks m8 , prob is diesel specific
Old 04-05-08
Yup sorry man couldnt find anything.
Saab Blackmista.
Old 04-05-08
Default OBD II Code Schema
Though this be madness, yet there is method in it
From the OBD-codes web site
http://www.obd-codes.com/faq/obd2-codes-explained.php
FAQ: OBD2 Codes Explained
OBD-II codes consist of a number of parts. Here is a sample OBD2 code:
P0171 Here is a breakdown of what each digit of the code means:
First Character - System
The first character identifies identifies the system related to the trouble code.
P = Powertrain
B = Body
C = Chassis
U = Undefined
Second Digit - Code Type
The second digit identifies whether the code is a generic code (same on all OBD-IIequipped vehicles), or a manufacturer specific code.
0 = Generic (this is the digit zero -- not the letter "O")
1 = Enhanced (manufacturer specific)
Third Digit - Sub-System
The third digit denotes the type of sub-system that pertains to the code
1 = Emission Management (Fuel or Air)
2 = Injector Circuit (Fuel or Air)
3 = Ignition or Misfire
4 = Emission Control
5 = Vehicle Speed & Idle Control
6 = Computer & Output Circuit
7 = Transmission
8 = Transmission
9 = SAE Reserved
0 = SAE Reserved
Fourth and Fifth Digits
These digits, along with the others, are variable, and relate to a particular problem. For example, a P0171 code means P0171 - System Too Lean (Bank 1). To lookup your particular code, visit our OBD Trouble Codes section.
Your codes are manufacturer specific and not generic or unversal. Sorry that we could not help.
Old 05-05-08
P1403 is EGR position sensor low (EGR position is 3,5mm lower than desired for 33sec)
P1269 is Injector 3 Correction Circuit. Short to B+/open
