vibration noise - SaabCentral Forums
Old 24-04-08
bigboy1 bigboy1 is offline
My Saabs: sabb 900s and a 900i
Unhappy vibration noise
Ive had this problem for a few months a vibration its hard to explain this but when driving their is a vibrating noise from whear i dont no, when on the motorway its loud it sounds if its coming from the back of the car ive checked all the usiale places when i turn the car left it seems to go away had new barings fitted to the front, back new drive shaft fitted 4 new tiers new stainless steel exust front to back wich was dun in a sabb garage that causte me an arm and a leg the car is a standard 900i non turbo the car has dun 149578 mils but still goes like stink witch still gives a few people on the road a shock and gets serviced on a regular bases. thought it might be the front engin mountings but they seem to be ok. I no its not a good explination but any help would be appreciated thanks
Old 25-04-08
Matthew's Avatar
Matthew Matthew is offline
Saab Mad
My Saabs: 900 S Aero Turbo, 9-5 Aero
Does the vibration go away different vehicle speeds? Can you "drive through" the vibration? Does it occur only when accelerating or also when cruising at constant speed?
Does the vibration vary with vehicle or engine speed?
The path of my life is strewn with cowpats from the devil's own satanic herd
Old 25-04-08
crusing at a constant speed thanks
Old 25-04-08
Matthew's Avatar
Saab Mad
Old 25-04-08
16saabs 16saabs is offline
My Saabs: 2x LPT convertible's, 1 x 900 SE
grab hold of the exhaust and give it a waggle, up down side to side if you hear and noise it might be that it not quite lined up properly and is vibrating on the underside of the car. check the rubber /mountings/supports on back box are both in place, as with one gone it will rattle a lot
22saabs
Old 25-04-08
yep tried the exust thing and its not that. it starts to get louder over speeds of 70 mph but its not as loud at slower speeds it wont go away apart from when im turning right then it stops then as i straighten up it starts again im going to get it up on the ramps tomorow and have a good look wether permiting that is
Old 25-04-08
yfs87's Avatar
yfs87 yfs87 is offline
sounds like an inner driver, check all your boots (inner and outter cvs) and make sure everything is supple and not cracked
On the road:
90 c900T16 cabriolet - red
91 c900spg - red
79 Porsche 911SC - red
Projects:
92 c900s 4dr - blue (on the backburner)
RIP:
93' c900s (drunk driver hit it)
90' c900s (deer found it attractive)
89' c900T (Friend crashed it)
88' c900T (parted)
87' c900T (parted)
89' c900s (parted)
My Bands Myspace
Facebook Me
Old 25-04-08
they have recently been replaced
Old 26-04-08
vbadoni91 vbadoni91 is offline
My Saabs: 91 Saab 900S
What has been replaced? The driver or the boots or the entire axle or all of them?
-vbadoni91
Old 26-04-08
both drive shafts have been replaced by a sabb specilast garage. I have just had it up on the ramps and cant find anything slack all seems to be fine
Old 26-04-08
Jim Mesthene Jim Mesthene is offline
Jack it up. Spin the rear wheels by hand while listening to the bearings.
Corporations are people! If you prick them, do they not bleed? If you tickle them, do they not laugh? If you poison them, do they not die?
Old 26-04-08
TooMany2cvs's Avatar
TooMany2cvs TooMany2cvs is offline
Saabista
My Saabs: '90 900T16 3dr - For Sale!
The shafts have been replaced, but have the "inner drivers", the cups on the gearbox which the driveshafts fit into?
Adrian
Soon to be living life on the road in an old VW
http://WhereverTheRoadGoes.com
Old 26-04-08
yfs87's Avatar
just because you have replaced the inner and outer cv's doesnt mean the drivers aren't knackered. i have replaced an axle only to find out the driver was scored and needed to pull it all apart again. my symptoms in that situation were much like yours
On the road:
91 c900spg - red
Projects:
RIP:
88' c900T (parted)
87' c900T (parted)
89' c900s (parted)
My Bands Myspace
Facebook Me
