stupid wire question - SaabCentral Forums
Go Back   SaabCentral Forums > Saab 9000 > Saab 9000 Workshop
Saab 9000 Workshop Saab 9000 (1985-1998) Technical Forum
Old 05-04-08
Giomeister's Avatar
Giomeister Giomeister is offline
My Saabs: 1992 Saab 9000 S
Default stupid wire question
I went in to check my starter and pull it out, do not be fooled it is easy to unhook but good lord is it hard to shimmy out.
While under the car i saw a stray wires. coated with black casing, and it was white.
What is the wire too, it is under the car and hanging....it is on the alternator side below the wheel. the alternator is my next project. I noticed after i took the wheel off, that the alternator wheel had a peice of liner gone. The liner that covers the wheel base area. It looks like it is 1 foot area, and only reveals the alternator wheel. anyhow another topic...
any ideas to what the wire could be, is it a ground strap? and if so where does it belong........
If the Army and the Navy were to look on Heavens scenes, they would see the streets are guarded by United States Marines.
Old 05-04-08
yaofeng's Avatar
yaofeng yaofeng is offline
My Saabs: '94 9kcs, 9kcde, '95 9kcse, all turbo
Does the wire have a connector at the end? If you want me to guess, oil pressure sender.
AIM:yaofeng4249
'94 cs, '94cde, '95cse, all turbo and 5 speed all gone,
4 bimmers now '95 525i, '94 540it/6, '01 540it, '03 325i
Old 05-04-08
Giomeister's Avatar
yes it does, a square connector after a closer look. It attached to a clip 2 inches from the oil filter. I found the wire and its end. i wonder what will this effect?
Old 05-04-08
Giomeister's Avatar
do you remember how you hook it up,. I have the clip with severed ends. and the wires i had were black and white.
Old 06-04-08
Giomeister's Avatar
does anyone have any idea to which side the black and white wires go once it is clipped. The lines got severed and i have to sauder.
not that i spelled it right i am sure.
but the clip for the oil sending clips on, and i have to repair wiring.
Old 06-04-08
yaofeng's Avatar
I am not familiar with 9k's prior to model year 94. Another possibility is the oil level sender as there is one on the sump prior to 1994.
AIM:yaofeng4249
