Hey guys, just a general warning: beware of getting parts from Napa! Ok ok, I know I shouldn't have bothered at all, but I was stuck in a different city, way past time I should have left, and I needed a clutch master cylinder ASAP. So I went to them, got it the next day, and had it installed (it was -32C there; even my ratchets were freezing up!). Lo and behold, the mechanic told me that somehow the shaft was short, but he installed it anyways. The shaft *just* cleared to let the clutch disengage! Here's what I found out after I got a junkyard replacement part:
![]() The top one is from a junker cylinder, the bottom one from the Napa unit. Go figure! But the more pressing problem is my CV boot I bought from them...6 months ago! And it's ripped already! No more Napa...they're good for other supplies, but definitely not for parts! I got myself some good German GKN boots online now, and replacing both inner and outer boots, but beware! li Arc |
| Sponsored Links | ||
Advertisement | ||
http://en.wikipedia.org/wiki/GKN Best boots on teh netz.
The path of my life is strewn with cowpats from the devil's own satanic herd |
I've had great luck with Napa parts over the years sorry to hear your luck hasn't been so good.
"May God have mercy on my enemies because I won't" General George S. Patton. |
At any rate, I'll pay for a good part because the labour in replacing the part most of the time just isn't worth it. Quote:
li Arc |
practise driving/moving without a clutch,
warm engine up a bit. switch off. engage 1st gear. start engine. (with slight use of accelerator pedal,will kangaroo a fraction but then go. and off you go. if you need/ want to change up, take foot off accelerator(revs drop) change from 1st -2nd and carry on each time up to fifth if required(or on motorway). to stop, just take foot of accelerator and knock out of gear and brake. to move off repeat process. slowish gear/speeds are recomended in built up areas as you might have to brake quick(but you only stall at worse, can do that with clutch working try this out on a country road, it is quite easy, and if you have done it previously, if your clutch ever fails, you will not panic about getting home if you miles away or local, and if you don't want to change gear again?, just drive home or to safety in first. just don't panic. I once had this happen in a small lorry(cable went) worked a treat, and to put icing on the cake about 3mnths later the gear lever came out of the socket as i lifted to put it in reverse, so had to drive through town IN REVERSE and go down a one way street P.S. it was a FORD TRANSIT
22saabs |
Personally, i like NAPA - they always have the parts in stock, and if they don't they get them within 2 hours.
Parts plus is good too - i bought my coolant temp. sensor there for $13
1986 Volvo 245DL - 1966 Coronet 440 - 1977 Puch Maxi 1HP - 1959 Honda CA95 - 1982 Honda V45 750cc |
I actually did this for a friend driving a Subaru...somehow his car was able to idle in 1st without stalling the engine! Then just basically heel-toe the whole way, and it worked like a charm. However, that wouldn't really work with our cars as there is no way to get the car to move if in a stopped position...I know I can't move the car with the starter alone, and it's also a very good way to blow your starter motor!
li Arc |
My "unclutched run" story happened to me on an african track. The Toyotas of the NGO I was working for were anything but up to snuff, so I had to drive about 70 kms without clutch on a battered trail after the master said bye. Was plenty of fun, and the fact it was a Toyoya helped A LOT! You can practically drive these beasts w/o clutch without any trouble. And after this happened I actually continued driving the cars like that. Juste for the fun...
The Soviet UAZ-469 I also drove on a regular basis there was a different story, though. More... saabish Cheers, Seb |
| Sponsored Links | |
Advertisement | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
