SAAB Owners Club (UK)
Home Saab Pictures Saab Classifieds Saab Dealer Listings Saab Forum
Go Back   SaabCentral Forums > Saab 9-5 > Saab 9-5 Workshop
Saab 9-5 Workshop Saab 9-5 Workshop (1997 to Present day) Forum
Old 21-03-08, 03:28 PM
Al's Red Wagon's Avatar
Al's Red Wagon Al's Red Wagon is offline
My Saabs: 1999, Cayenne Red 9-5, 2.3 Wagon
Default Sparkplug gap and fuel economy
When I have put plugs in, in the past I trusted that they were pre-gapped as they said on the box...
When I put my new plugs in The other night and put them on my feeler gauge I found that even my .88mm feeler couldn't get through. I opened it up to 1.1mm.
However my fuel economy was quite low for the trip I just took. Only 20mpgs - usually I get 24-26 with a luggage carrier on top and a full load. The car is running fine, no CEL's or anything...
Would a gap that is too big cause this?
Old 21-03-08, 11:13 PM
saabcog's Avatar
saabcog saabcog is offline
My Saabs: 2000 SAAB 9-5 2.3t BSR Stage 1
I'd be willing to adjust mine to .88mm and see what it does to my MPG. I get 25mpg with 1.1mm gap at the moment. I'll run upstairs and re-gap mine and then post again at the end of the weekend with any results.
My SAAB
Old 22-03-08, 12:53 AM
Awesome - Thanks...
FYI Aero spec is .9mm-1.0mm
Old 22-03-08, 01:23 AM
saabcog's Avatar
I took a drive to dinner and back with the new gaps. Right away I see a major difference; the car's idle is much quieter and smoother. I'm also happy to report that my butt-dyno says the performance has not decreased.
Even if this experiment doesn't show any gas mileage improvement, I think I'm sticking with the smaller gap for the improved idling.
Have you experienced a change in the car's idle with these larger gaps?
1.1mm
.88mm
My SAAB
Old 22-03-08, 06:28 AM
rolly rolly is offline
My Saabs: 2003 95 305Hp Hirsch Wagon, 04 Clio RS
Since I have only had mine for while and going through all the service items to give it a clean bill of health. I checked the plugs and they were at 1.2mm a bit due to wear no doubt, so I gapped them down to .9mm and straight away noticed better idle - cannot comment on the fuel milage as I have only filled up with my second tank of 98 when the PO only used 95, and it is on the decrease anyways(l/100km)
Old 22-03-08, 04:37 PM
blinktude's Avatar
blinktude blinktude is offline
My Saabs: '03 9-5 Aero, '02 Trailblazer
ohh!
this could possibly be the solution to rough idle on our 4 cylinder models!
high five
Old 22-03-08, 05:27 PM
Any gear heads that explain why the Aero gap spec is a bit smaller than the lpt gap spec?
Old 22-03-08, 05:54 PM
turbophille's Avatar
turbophille turbophille is offline
My Saabs: 2000 9-5 Areo auto
talking from experience (not with Saabs), a larger gapped plug can have its spark blown out under higher boost
Old 22-03-08, 06:02 PM
Raven18940's Avatar
Raven18940 Raven18940 is offline
My Saabs: 2001 9-5 Aero 5spd
Exactly, the denser the fuel/air mixture, the harder it is the jump the gap.
Originally Posted by VikingSpirit
We can neither confirm nor deny the rumours that there is, was or ever will be "females" or "Message Boards" on the interweb...
Old 22-03-08, 06:07 PM
stipud's Avatar
stipud stipud is offline
My Saabs: 1999 9-5 2.3lpt Auto Nordic Stg. 3+
Might also have something to do with using platinum plugs instead of copper.
Tuning: Info // Pictures
Stereo: Info // Pictures
>>> THE Stereo Upgrade Thread <<<
Old 22-03-08, 06:08 PM
spot on mate. the lpt pushes 8psi whereas the aero pushes 15psi, thats a big difference! on lesser cars, if u doubled the boost you could then have to look at race coils, bigger leads, uprated ignition amps ect
Old 22-03-08, 06:29 PM
So what about the Nordic/BSR folks who are at at 20+pressures with the lpt? I haven't heard anything about those people gapping their plugs smaller...
Old 22-03-08, 06:30 PM
Chris 9-5's Avatar
Thats true - I was told to run the NGK BCPR7ES with a 1.0mm gap.
But I dont think its called a LPT anymore
The Godfather ~ Xtreme 9-5
"I know a lot about cars. I can look at a car's headlights and tell you exactly which way it's coming" ~ Mitch Hedberg
Old 22-03-08, 06:31 PM
Originally Posted by Chris 9-5
Thats true - I was told to run the 7's with a 1.0mm gap.
that's confusing 'cause that's upper limits of aero and lower limit of lpt...is that smaller than you were running before?
Old 22-03-08, 06:33 PM
Chris 9-5's Avatar
I didnt really have a "before"
However I tended to use NGK BCPR7ES-11 (pre gapped at 1.1mm)
Old 22-03-08, 06:40 PM
thats the plugs i was given by my local parts store when i did my first service. a month ago i re-gapped to .9mm and car runs much smoother now
Old 22-03-08, 07:04 PM
saabcog's Avatar
Would anyone else be willing to narrow the gaps on their plugs and report back? I'd like to see more data sets.
The idle is smoother for sure. No change (up or down) in MPG so far, but it has only been a day.
Where I really want other people's impression is with the car's behavior at WOT when running smaller spark plug gaps. I don't want to say anything more until others try this out because I have no way of really measuring what I may be feeling and I know how easily the mind can be tricked when it comes to cars. (How is that for an abstruse statement.)
My SAAB
Old 22-03-08, 07:08 PM
Chris 9-5's Avatar
That was so abstruse I had to look it up!
http://en.wiktionary.org/wiki/abstruse
Old 22-03-08, 07:18 PM
saabcog's Avatar
Yeah, I'm usually obtuse.
My SAAB
I'll be going down to .9-1.0 for the ride back on Monday....but my only real concern in MPGs...My wagon has never let me down at WOT (except for that mustang once... )
copyright © 2003 saabcentral.com, All rights reserved - website by WDD serviceshttp://www.whiter.co.uk - valid xhtml - valid css
SaabCentral is an independently run website and is not affiliated in any way to Saab Automobile AB
