Random misfire - SaabCentral Forums
Old 21st March 2008
white96850turbo white96850turbo is offline
My Saabs: 1999 BMW 328is
Default Random misfire
Hey all,
Well, today I finished my turbo install in my 1996 900se turbo (with the stock Garrett T25) and did some tune up things too (fuel filter, spark plugs, air filter, cabin filter, oil pan, GS motor and trans mounts, new oil, and fresh coolant).
But, after starting and letting the engine run for a good 15 minutes the car already set a code. I forgot the code number, but it was a random misfire (didnít say what cylinder) and it was bad enough for me to tell it was missing by the sound of the exhaust. I also tried to see if it was any different under load or through the RPM range and it wasnít any better. Also, after the turbo went and started blowing oil, the car sat until I had enough money (and after that, time and good weather) to do the rebuild. So the car sat about 6 months without running (bad idea....I know).
Any ideas on what could be the problem? I'm sure the gas is starting to turn bad, but I donít think it would be that bad. Right now I'm thinking that it's either the DI Cassette, or a plugged Fuel Injector, any good ways to test these with out spending tons of money?
Thanks,
~Brandon
EDIT: Just remembered that both O2's are bad (car was dumping oil into the exhaust) and it sounds like one cylinder isn't firing at all.....
-1996 Saab 900 SE Turbo
-1996 Volvo 850 Turbo
Old 21st March 2008
Any ideas on what to do?
Old 21st March 2008
earthworm's Avatar
Saab Sage!
The usual
compression
timing
condition of the ignition
It does sound as if seals and drying and breaking..
The gas may still be good - try some fuel stablizer or some ether..
Good luck
The earthworm
'96 900S, Automatic
Old 21st March 2008
jv_72_jv jv_72_jv is offline
My Saabs: 90' 900s 3dr (sold), 88 900s 4dr
Originally Posted by white96850turbo
Hey all,
Thanks,
~Brandon
I suspect the DI cassette. You may have broken something when you removed it to change the spark plugs, but put a tank of fresh gas in it and see what happens
Old 21st March 2008
Yea, I guess I'll be running down the basics and seeing whatís good and whatís not....The reason I donít think its the DI is because it was replace once already by the PO but I'm not sure when (car has 150,000 miles). How long do these DI last? Any sure fire way to check and see if thatís the problem with out spending $380 on a new one?
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
