350whp for less than 1600$ - SaabCentral Forums
Go Back   SaabCentral Forums > Saab 9-5 Mk.I, 1998-2009 > Saab 9-5 Performance, Mods & Tuning
Saab 9-5 Performance, Mods & Tuning Covers Tuning & Performance modifications for the Saab 9-5
Old 20-03-08
VwAlex VwAlex is offline
Default 350whp for less than 1600$
At least that's what I'll be trying in the next month with my used to be dailydriver 2000 9-5 lowpressure.
I usually had my 1991gti with a 1.8t 20v fitted and a whole lot more so I never gave any attention to the wagon exept maintenance so it'd get me around. Then I had to rebuild the head because the previous owner probably overeved it and some valves where bent, I built a 3inch exhaust for it and left it alone again for a while. Then it started knocking, i didn't care and just drove it slower until one day where i revved it and it died. Rod bearings where gone and I knew it. So it's been sitting in the snowbank ever since, because I really did not want to know anything about b235 anymore. For some dumb reason I sold the vw, to fund my 71 bmw projet. And I have no more car...Then it occured to me, theo nly thing i really hated about the 9-5 was that the engine was nothing like the 9000 I had and it was slow.
Check the garage and find I do have,
-b234 crank, rod
-A couple intercooler setups I tried on the vw
-T25 flanged turbo from t28 to gt3071r
-some injetors
-Stock manifold is already t25 and fairly well designed, so that a great time/money saver.
-B234 internals should make this engine stout at least I hope.
-There is a whole lot of room for the intercooler in the front wih is great because the ones I have a fairly big and I will never use a water to air intercooler anymore
-Piping is also a breeze with a lot of room and smile design
-t25 turbos while being restritive higher up and plentyfull and cheap used and should still be more then enough for 350whp and early spool
Am I forgetting something?
Old 20-03-08
2 questions I had:
-where does the stock clutch let go?
-can I delete the tration control or at least have it off when I start the car?
Old 20-03-08
Chris 9-5's Avatar
Saab Sage!
My Saabs: .
Exhaust and Software (ECU Mapping)
Edit I found this:
I built one 3 years ago magnaflow 3inch cat and magnaflow 3 inch straight muffler.
Just software then - possibly fuel pump
Have you discussed this with a software tuner? They would probably be able to advise on the injectors you will need - its important that the hardware matches the software / and vice versa.
With 350bhp at the wheels I would suggest a stronger clutch - SPEC perhaps - the clutch is a big, gear box out job, so you only want to do it once!
Old 20-03-08
Kermit's Avatar
Kermit Kermit is offline
Saabista
My Saabs: Citroen C5 2.2HDi
And if you do uprate the clutch its worth doing the master/slave cylinder. You'll kick your own *** if it goes 3 months later.
1...../ 5
Old 20-03-08
Al's Red Wagon's Avatar
Al's Red Wagon Al's Red Wagon is offline
My Saabs: 1999, Cayenne Red 9-5, 2.3 Wagon
T25 Turbo? Will stock software have a problem with that? I agree with Chiris on the software, but you'll need to see somebody about it. It doesn't sound lcommon enought to be something somebody has on the shelf...
Old 20-03-08
aeropilot's Avatar
aeropilot aeropilot is offline
My Saabs: MY04 Hirsch 9-5 Aero 4-door auto
Well custom software for the bigger injectors and that turbo combo etc will probably use up most of that $1600 budget....
And as Chris said you'll need a new fuel pump for the injectors as well.
Oh and a big intake pipe.
Blessed is the sound of a ninety-two on nitro......
Old 20-03-08
Raven18940's Avatar
Raven18940 Raven18940 is offline
My Saabs: 2001 9-5 Aero 5spd
WHy not get a whole B234 short block, the rods and crank aren't the bits you'd want anyway. You want the sturdier pistons and oil pump.
Originally Posted by VikingSpirit
We can neither confirm nor deny the rumours that there is, was or ever will be "females" or "Message Boards" on the interweb...
Old 20-03-08
I have a whole b234 but it's off a 93 so different bellhousing pattern. I was going to use the pistons and oil pump, you have no hoice either way with the b234 short rods.
Just found out the cams are another hot bit that I want to transfer
Just happens that my buddy cracked the SAAB coding and can now do me a custom chip and maybe put something on the market. His software is the most used and praised for vw's and he happens to owe me a favor Siemens 630cc are cheap if you know where to look, under 300$.
Clutch is something I'm not sure yet. I had mine rebuilt for a bit more lamping power 2 years ago and it looks awesome now. Maybe I'll give clutchmasters a call, as I never want to deal with SPEC again, big issues with their product and service.
Fuel pump, I had forgotten, another 200$, it goes quick even on a budget haha!
Piping is really no issue, I have a good amount of material already and a MIG, a TIG, a beadforming machine.
Heres the last car I put together for my buddy, same software compagny too :
http://www.youtube.com/watch?v=3N7EH7QFlNU
Old 20-03-08
More questions :
- I can't make up my mind on the balance shaft, no engine I ever had, had those. I did remove them on a mazda 3 once and I'm pretty sure it was responsible for an engine failure much later on.
- What kind of power can the tranny reliably take, if I make sure there'S no more wheel hop?
- You guys want to see anything done/replicated?
Old 20-03-08
Chris 9-5's Avatar
Saab Sage!
My Saabs: .
If I were building an engine I'd remove the balace shaft chains and suffer the lumpy idle.
You will need to uprate the fuel pump with the 630cc's
Sounds great but are you sure he's "cracked" T7 (9-5's) not T5 (900 & 9-3's) software?
Originally Posted by stevehayes01
You can find more on this at ecuproject.com
OK so you T5 guys need to get on this and test it out.
************UNTESTED AND NOT SURE IF IT IS 100 CORRECT**************************
ORiginal Refering Page
OverviewThis article describes how to calculate the chesum for a Saab Trionic 5 ECU with HexWorkshop.
Calculate the checksumOpen the binary file in HexWorkshop.
Mark all data until the field in the end that is filled with FFFF. Like this:
http://www.xendus.se/images/t5/t5crc1.PNG
In the menus select: Tools->Calculate Checksum...
Select Checksum (32 bit) and then click on Generate. Like this:
The calculated checksum is displayed in the bottom field of HexWorkshop. This value should be put in the very end of the binary file. Like this:
Old 20-03-08
He's cracked t7/t8, he wont work on anything not obd2, flash loading being the prefered method and personal flash loaders will be available soon, maybe even for Saabs if the demand is there. I've seen him flash big turbo fsi vw wich are far more omplex than t7 or t8, bmw 335 wich he can't legally offer because of bmws politics in that area, his s60r volvo software is loved and vw software is unmatched so I'm not worried in that area. Dyno, a/f and ignition timing will be available for you guys to see once it'S done.
Lumpy idle is the only thing the balance shaft will do? I'm kinda stressed with the b234 internals having such a bad rod ratio in a big engine like that...
Old 20-03-08
Chris 9-5's Avatar
Saab Sage!
My Saabs: .
He's cracked t7/t8, he wont work on anything not obd2, flash loading being the prefered method and personal flash loaders will be available soon, maybe even for Saabs if the demand is there. ..
Impressive
Portable programme carriers (PPC) have been around for a while:
http://www.partsforsaabs.com/bsr_ppc.php
Or am I confused already
Old 20-03-08
Impressive
Yes but not from unitronic, just another option and PPC for big turbo software to
Old 20-03-08
Jssaab Jssaab is offline
My Saabs: 2000 9-5 320hp, 2003 Aero Hirsch "Clone"
I hve the 9k turbo on my LPT ( rebuilt with GT 28 on both sides. Made 250 WHP with Aero Stage III tune.
It seems maxed out now at 320 WHP ( rated at 350 BHP) with a custom tune.
I am running Stock Fuel pump, larger IC T5 cams and 50# injectors. ( and forged pistons and a few ohter things I forget now.)
Old 21-03-08
Raven18940's Avatar
All those cars are based on a Bosch system, the Trionic is SAAB's own system.
Old 21-03-08
Trioni is a bosch system modified by SAAB, different encoding but by no means any more complex than bosch.
Old 21-03-08
Raven18940's Avatar
I'd really like to know how you reached that conclusion.
Old 21-03-08
Cracking the ecu Nothing bad with that as bosch systems is the the most advanced out there.
Old 21-03-08
So Since when does Bosch have ion sensing ingnition ? Lat I heard it was still using vacuum ..
Old 21-03-08
Had a look at bmws recently? Or the ESP is bosch, trionic is still saabs own system but don't think it world appart from anything else.
