84 900T odometer - SaabCentral Forums
Old 03-03-08
eric43 eric43 is offline
My Saabs: 1984 900T, 1997 9000 Aero
Default 84 900T odometer
My odometer (total and trip) stopped working a week ago, so used john-w's description (06-12-01) of how to take the thing out and fix it. Got the speedo out, took it apart, put it back together, but couldn't find anything wrong. Spun it with a drill, and it seems to work fine. Sadly, I broke the needle off trying to pull it off, so will have to fashion a new attachment. I'm reluctant to reinstall it not knowing why it didn't work before. Any ideas on what happened?
Also, what's the purpose of the tiny drive cable in the upper right quadrant of the speedo?
Saabs: expensive and built to stay that way
Old 03-03-08
SteveTheFolkie's Avatar
SteveTheFolkie SteveTheFolkie is offline
My Saabs: 1987 900 8V
I think it drives a counter for the oxygen sensor light (comes on at what, 80K intervals?).
As for the odo working - chances are that you "shook" the errant gear back into position while pulling the instrument cluster out - if you didn't re-fasten (glue) the gear into it's correct location I predict that your odo will stop working somewhere down the road -
Old 03-03-08
'Course, I couldn't determine what gear was out of place. I don't look forward to taking the thing out again (just hope I can get it all back in right!), but I better make sure I make the needle removable. Thanks!
Old 03-03-08
There's a gear attached to a shaft that drives the odometer - if it's sliding on the shaft (you can move it along the shaft) I'd suggest fixing it with a bit of epoxy (careful not to get it on the surfaces where the gears engage!) before you put the cluster back into the dash - I THINK there's a picture in one of the repair locked threads - in fact there is - on the second page of this discussion thread there are some really good pics and explanations -
http://www.saabcentral.com/forums/sh...light=odometer
Last edited by SteveTheFolkie; 03-03-08 at 02:39 PM. Reason: Found referenced thread
