Somebody explain: Saab XWD vs Acura - SaabCentral Forums
Go Back   SaabCentral Forums > Saab Café > The Lounge
The Lounge For Saab related posts of a non-technical nature
Old 26-02-08
Saaby's Avatar
Saaby Saaby is offline
My Saabs: 1993 Saab 9000 CSE
Default Somebody explain: Saab XWD vs Acura
I was just reading up a little on the Saab Turbo X (Don't get me wrong, I'm as big a fan as anybody else here, I've just been way way behind on current events for awhile now. Saab-wise and other wise) and I have a question.
Supposedly the XWD system is revolutionary because it can pass power left to right as well as front to back, but I thought Acura has been doing this for awhile now with their SH-AWD.
Anybody care to explain the differences, and advantages of the Saab system, not just vs. a traditoinal AWD system, but specifically in comparison to Acrua's?
Old 26-02-08
boon94's Avatar
boon94 boon94 is offline
My Saabs: '09 Forester XT
Both systems accomplish the exact same thing, for some reason people think that Sh-AWD can also split torque independantly between the front wheels, however it cannot (same as xwd).
SH-AWD uses twin cluches in the rear differential to distrubite between front back torque, as well as rear left/right torque
XWD uses a torque distributor to seperate front and rear (called a TTD?), and a seperate (eLSD) unit to distribute between right and left on the rear wheels.
Both systems are capable of the same thing. Which one has the better Computer Controller? Which one has the ability to respond faster and more effectively? supposably the XWD unit
Oh Forgot to mention, SH-AWD can only set a maximum of 70% torque to one rear wheel, while XWD can send 85%
Hondas Video
http://world.honda.com/HDTV/news/2004-4040401a/
XWD video
http://www.haldex-xwd.com/
Old 26-02-08
ACBarnett ACBarnett is offline
My Saabs: 2000 9-5 Aero
don't forget that mitsubishi has had a similar system in the evo for a few years, and I think nissan has offered something similar in some of the skylines as well
Honda's setup is much more complex than XWD, the clutchpacks scream "wear part" and will surely get expensive to replace later on. On the flipside I think it's a bit lighter than XWD and it's probably a more advanced setup mechanically speaking. All the eLSD is is another haldex wet clutch hooked up to one of the output shafts of the diff.
Old 26-02-08
queryanalyzer queryanalyzer is offline
My Saabs: None - '02 9-3 5spd(RIP), '96 900SE(RIP)
Thanks for that. That was informative
I didnt know about Haldex's use in TT and Volvo.
Old 27-02-08
SaabKen's Avatar
SaabKen SaabKen is online now
My Saabs: '06 9-3 2.0T SportCombi; ex-'93 9000 CSE
It's all here
http://en.wikipedia.org/wiki/SH-AWD
http://en.wikipedia.org/wiki/Haldex
"Honesty is the best policy, but insanity is a better defense." - Steve Landesberg
SAAB CLUB of WESTERN CANADA (SCWC)
Old 27-02-08
TooMany2cvs's Avatar
TooMany2cvs TooMany2cvs is offline
Saabista
My Saabs: '90 900T16 3dr - For Sale!
AIUI, the Haldex system Saab are using is the first live implementation of a new generation, so it's theoretically that bit better than existing Haldex systems.
Adrian
Soon to be living life on the road in an old VW
http://WhereverTheRoadGoes.com
Old 27-02-08
Mattlach's Avatar
Mattlach Mattlach is offline
Location: Winchester, MA, USA (formerly Göteborg, Sweden)
My Saabs: 2011 9-5 Turbo4 Premium 6spd Manual
An interesting thing about the TTD system in the Turbo X, is that it senses when you are undergoing hard acceleration (kick-down?), and immediately shifts torque to the rear wheels.
If I am not mistaken, other systems like it, (including Sh-Awd) wait for wheel slip, and then compensate, causing significant lag.
My posts are intended for community use only. I do not permit Saabcentral.com, any affiliate or anyone else to commercially use, charge for, or in any other way profit from any of my posts or linked images without my express written consent. In all cases I remain the sole owner of any content originated by me which I have posted on this, or any other site.
Old 27-02-08
Saaby's Avatar
Ok, so the setup itself isn't totally new, but the way they're controlling it is smartest of all.
Kind of like how I use a Mac, and Apple don't always invent totally new stuff (Although sometimes they do) but they have a way of taking an existing technology and really improving the heck out of it.
Old 27-02-08
mulik51's Avatar
mulik51 mulik51 is offline
My Saabs: 1995 Saab 9000 CSE 5 speed; Porsche 928
Garage
Isn't the haldex system on S60R supsed to be able to deliver traction even if 3 wheels are on a slippery surface?
KLim
The only way to measure true happiness is in terms of boost
270hp/396ft/lb. Maptun stage 3 ECU, JT 3 inch downpipe, cat and the rest of exaust, k&n filter.
Poly trans bushing, poly torque arm bushings, solid engine mounts, poly sway bar bushings, poly sway bar link bushings, Zimerman cross drilled front and rear disks, perfomace pads.
Old 27-02-08
brunp's Avatar
brunp brunp is offline
My Saabs: none
Just curious how this differs from the Audi systems as they claim to have what the new Haldex system will achieve on our Saabs?
Paul
Current Car(s): 2006 BMW 325i, 1998 BMW 328is
Past Cars:
2007 Saab 9-3ss AERO
2004 Saab 9-3ss Linear
2003 PT Cruiser
2001 Volvo S40
1990 Honda Accord EX-R
Old 27-02-08
snowboardin58's Avatar
snowboardin58 snowboardin58 is offline
My Saabs: 94 900s,00 Vig,01 SE Wgn,73 240Z,01 Vig
Sorta. Except in reality, XWD really is the better choice, and the smarter system.
Old 27-02-08
boon94's Avatar
apple is the spawn of satan
Paul
They use brakes to redistribute power, we use machines that cause less power loss and more performance
Old 28-02-08
Saabista
Any 4x4 system with diffs which aren't totally open will be able to do that.
If the centre diff's totally open, all you need is to lose traction at one wheel and you're stuffed.
If the centre's locked, then you'd need to lose traction at one wheel each end to be going nowhere.
Lock one end (usually rear - lock the front, and you only go in a straight line...) and you'd need to lose traction on both wheels that end plus one the othe end.
Lock both ends, and as long as one wheel's gripping, you've got traction.
With partial locking, it's just a question of the maximum torque you're going to get to that wheel.
Adrian
Old 28-02-08
SaabKen's Avatar
Maybe. But Bill Gates III is the true 666
Old 28-02-08
Saaby's Avatar
Originally Posted by SaabKen
Ok, sorry I even tried to draw that conclusion. Moving on...
Old 28-02-08
The S60R doesn't have a center diff though, it's a haldex car remember, so it has the haldex clutchpacks instead. Having driven one and poured over the description of the Haldex system it has I think the "maintain traction with 3 wheels spinning" spiel has nothing to do with it's awd hardware and everything to do with Volvo's dynamic stability control/4c. It still applies torque through that one wheel with traction, but it's by applying the brakes on the other three.
That's why they come with such huge brakes
My bigger question for xwd is whether it will drive like the S60R with it's 95/5 baseline front/rear torque split, or like a 50/50 Audi or Subaru. The Audi/Subaru style awd systems are incredibly linear in their power delivery, especially when redistributing the torque. The Haldex system on the S60R on the other hand is crude and unpredictable, it will drive like a 300hp fwd car until the front wheels start spinning then all of a sudden it shunts 30-50% of the torque to the rear making it a really easy car to snap oversteer in poor road conditions.
Hopefully the Turbo X drives more like a real Quattro Audi or Subaru and less like the other fwd/awd Haldex cars that are out there.
Old 28-02-08
boon94's Avatar
XWD is supposed to be so fast and smart that you wont even know its working, you'll just think your a driving master
Old 28-02-08
900t's Avatar
900t 900t is offline
Saabista
I think SH-AWD is shifting torque splits all over the place all the time, if it waited for wheel slips then it wouldn't really accomplish anything in terms of the "super handling". The point is to over-torque the outer wheels and such to kind of "push" the car around the bend. The differential normally sort of does this naturally but not really (more just changing speeds).
Old 29-02-08
Saabista
Of course it does.
There y'go. That's the diff. It's a clever diff, sure, but it's a diff.
Adrian
Old 29-02-08
SaabKen's Avatar
Several 2009 Hondas/Acuras will feature their latest iteration to be called SDH-AWD: "Super Duper Handling AWD"
