Instrument cluster removal - SaabCentral Forums
Old 25-02-08
cnskate cnskate is offline
My Saabs: 1994 900s 133k
Default Instrument cluster removal
Do the instrument cluster come out from the back or the front? I'm wondering how much stuff I need to take off to replace the cluster. Thanks
Old 25-02-08
earthworm's Avatar
Saab Sage!
Front
I pull the steering wheel, but this is not necessary.
Its still a good hour of work, with all the panels and switches.
The earthworm
'96 900S, Automatic
Old 25-02-08
So that whole front panel has to come out? I wonder if I'll need a stereo puller tool.
Old 25-02-08
jonnyfgroove's Avatar
jonnyfgroove jonnyfgroove is offline
My Saabs: - 96 900SE Coupe - 5spd, 170k
Check out this link.
Excellent Saab DIY sites:
PMI - Dip - Munki - Michel Briand - Mattias
Old 25-02-08
Thanks for the link. Ugh, looks harder than I thought.
Old 25-02-08
Eric in Lockport, N.Y.'s Avatar
Eric in Lockport, N.Y. Eric in Lockport, N.Y. is offline
My Saabs: '95 900SE 2.5L V6 'VERT "resurrected"
Not hard, just time consuming.............. been there done that.
Old 25-02-08
neomagus00 neomagus00 is offline
My Saabs: 2K 9-3 Conv, Stage 3 HW
i have a 9-3, but i don't find it difficult at all to pull this stuff off... just be careful with the AC vents, mine have a tendency to fall off, and they're not easy to put back together.
Old 25-02-08
turbojohnny turbojohnny is offline
My Saabs: '95 900 se
very true, when i pulled that front cover piece off one of the vents fell out and i spent probably a good 10 minutes putting it back together
Old 26-02-08
coreyeroc's Avatar
coreyeroc coreyeroc is offline
My Saabs: 1995 900s
Sorry, i cant help you with dash removal.
but related to this - do you guys know if there is a spot where I can shim my dashboard (really slightly). It has a slight rattle at times which drives me nuts, and rather than pulling the entire dash off to find one or two loose mounting screws, i'd like to see if a shim will do. I can hold/push the dash up really lightly and it stops completely. Could I put 1 small shim on each side by the door jamb to alleviate this? Any ideas?
Old 04-03-08
yep, it was pretty easy, thanks for the encouragement. The .99 cent cluster I scored off of ebay did the job.
Old 05-03-08
hawkmoon hawkmoon is offline
My Saabs: 96 900S 4 door
Just a note for anyone having problems with guage cluster. I took mine out and found a couple slightly loose screws on the circuit boards. I merely tightened them and re-assembled and that took my guages from rarely ever working to almost always working. I guess a $1 cluster would work better but it may be something to try.
1996 900S
2.3 FI
Old 05-03-08
john bernard john bernard is offline
My Saabs: 1995 900SE convert. V6
In the Tech. Help section on this web site I think there is a guide for dashboard removal (may be listed as instrument cluster removal). Anyhow, this includes a sketch showing the location of each of the dashboard holding screws. My guess is that one or more of these is missing from your dashboard. I think there are something like nine screws. Also, the installation of the dash at the left bottom is a little tricky, It has to be raised a little to go in properly.I had to use a flat blade screwdriver to lever up the bottom left to get it over some obstacle to get it to install.
Old 08-03-08
The diagram you're referring to doesn't show screws for the entire dash, just the piece that surrounds/holds in the radio, sid, gauge cluster, etc. I'm guessing if there's a rattle it would be something missing in the dash piece that spans the width of the car.
Where do you touch or hold to make the rattle stop?
Old 08-03-08
earthworm's Avatar
Saab Sage!
Small pieces of rubber from an old tube
sections of foam tubing used in concrete and building
a rubber band, NOT good for more than 60 days..
model aircraft fuel line
vacuum line
Great Stuff , use this in the voids and cavities.
The earthworm
'96 900S, Automatic
Old 10-03-08
coreyeroc's Avatar
My Saabs: 1995 900s
thanks for the replies fellas. If I push up slightly on the center on the dash, it stops completely. It just feels a little loose on the back end. I would guess too, that a mounting screw is loose, if not a few. Its not terrible or anything, just one of those things that drives only you crazy..
The vacumm line and foam is a good idea earthworm. I think I'll try that and see what we get.
