Fuel pump Replacement - Page 3 - SaabCentral Forums
Old 12-11-08
hkayssi hkayssi is offline
My Saabs: 1997 900S
You buy this
http://www.eeuroparts.com/Main/PartD...px?id=12806113
Old 16-11-08
Connectisaab Connectisaab is offline
My Saabs: 1997 900S; 2.3 L; std.
Default No Need to Buy Anything: Use Epoxy to Fix Retainer
If you have the broken piece, there is no need to buy anything. Just seat the check valve back into its well, and then use Epoxy to glue the holder back together. Epoxy is fuel resistant and stronger than the original plastic that the holder is made of.
Hints: Use brake cleaner to get any dirt, grease, oil or gasoline that may have contaminated the plastic.
Be liberal with the amount of glue that you use.
Most important--WAIT at least 12 hours for the Epoxy to cure before activating the fuel system.
Old 16-11-08
Default Interesting Bracket
Hkayssi-Thank you. Interesting bracket. I thought about fabricating fabricate something similar. How does it attach? Does the self tapping screw go through the top of the fuel pump holder?
Old 12-01-09
C.S.'s Avatar
C.S. C.S. is offline
My Saabs: "HER" 1999 9-3 SE $ pit
Thank you for this thread... the information was excellent and I greatly appreciate it.
We used (very carefully mind you) an air chisel and pre-mapped our cut by using a very small mirror and flashlight. We also took a few digital pics and measurements from the piece that we "can open" cut. It should go back together smooth and easy.
No animals or small children were harmed while carrying out this procedure.
Pictures of the "special ring removal" tool to follow... shortly... right Al?
this is a signature
Old 12-01-09
My Saabs: 1997 900S
Use the links I sent you in my reply to your email
Pics of the tools are up to by the way.
Old 12-01-09
C.S.'s Avatar
this is a signature
Old 08-02-09
skypny skypny is offline
My Saabs: '99 9-3 Viggen
Default lock ring stuck?
Any ideas for what to do if the lock ring is completely stuck shut? The thing absolutely refuses to budge.
Old 08-02-09
snoborderphx's Avatar
snoborderphx snoborderphx is offline
My Saabs: 94 Saab 900SE Turbo
Skypny,
Try the ring removal tool with a longer breaker bar, also, I've used a rubber mallet and "tapped" ever so slight hard as heck on the outside of the ring, and it loosened up. I've always been able to get mine off with a set of pliers spread apart and a long bar in between after tapping the outer ring...
Sno
Good Luck!
Old 09-03-09
saab_lpt saab_lpt is offline
My Saabs: 2001 Saab 9-5 LPT
Reviving an old thread...
So my fuel pump crapped on me at 94,400 miles. I have a half tank of gas and I'm going to change out my fuel pump insert with a Walbro unit. I don't have the means (AKA: I'm tired of throwing money at the Saab ATM) to syphon the fuel from the fuel tank, so how dangerous would this task be, at 1/2 tank fuel???
EDIT: I know this is the 9-3/NG900 thread and I have a 9-5, but...euh...this is more of a "general" question that even a Honda Civic owner can ask.
Old 09-03-09
dzlsabe dzlsabe is offline
My Saabs: 06 93 TiD Combi, New engine 95 Combi
Your in luck with a 9-5! They have an access hole underneath the back seat already...the procedure is basically the same as mentioned in this thread.
Only US diesel?? 03 93 Cosmic Blue
Also Black 06 93 Combi, White 89 900TCV
Old 09-03-09
earthworm's Avatar
Saab Sage!
Do remember having a certain amount of fuel in the tank.
Before the task is complete, check that the fuel level float moves freely and that the gage reading is the same as before.
Also, run some tests on the old unit and compare them to the new....this may be interesting, and its very easy..
The earthworm
'96 900S, Automatic
Old 09-03-09
Thanks for the replies, dzlsabe and earthworm. I'll definitely make sure the gauge reading is the same as before and try to run some comparison tests. There's an FAQ on this procedure in the 9-5 workshop, but I found that this thread was a lot more detailed than the 9-5 one.
Soooooo...the half-full fuel tank shouldn't be a major issue then, I'm assuming...
Old 12-03-09
rollingtomato rollingtomato is offline
New Member
My Saabs: 1996 Saab 900se, 4cyl. turbo, 5-spd
Hey, thanks for the thread, it's helped a lot. I replaced my fuel pump but after that the car started and ran for about 30 seconds but i realized gas was flowing over from the top of the tank so i shut it off. I dropped the tank to realize one of the retainer clips was broken. I fixed this problem but now the car wont even start. I hear the fuel pump is working and everything is hooked up right... however now I noticed a small hose is split coming from the top of the tank towards the front of the car.. I don't have a picture of this hose but this is a picture of where a connector piece is about a foot after the tank...[img]file:///C:/DOCUME%7E1/Owner/LOCALS%7E1/Temp/moz-screenshot.jpg[/img][img]file:///C:/DOCUME%7E1/Owner/LOCALS%7E1/Temp/moz-screenshot-1.jpg[/img]
I need to know what this hose is for and whether or not this could be keeping the car from starting.. or if anyone has any ideas as to what I should do next to figure out what the problem is.
thanks for any help
Old 12-03-09
Saab Max's Avatar
Saab Max Saab Max is offline
My Saabs: SAAB 900SE V6 2.5L / 9³SE 2.0/03 9-5Areo
thanks for any help
I was wondering if you switched the return lines ( 2 hose that has a yellow holder ontop)......... and if u can take a picture of where this hose is running from the gas tank.......
Old 12-03-09
nicho919 nicho919 is offline
Looks remarkably like the LS1 trap door mod we did on my friend's 00 Trans Am. A dremel works wonders at this. After you're done, fabricate a cover plate.
Old 12-03-09
earthworm's Avatar
Saab Sage!
The 1" ( or so) hose appears to be for venting purposes..
Drop her again...or do it the easy way.
So the Pontiac is the same way as the Saab 900, thats GM for you...
The earthworm
'96 900S, Automatic
Old 12-03-09
New Member
the lines are where they were before, i didn't remove the other hose... i don't have access to the hose because the tank is back up. Im planning on dropping it tomorrow so ill post a picture then
Old 12-03-09
soccerrplyr's Avatar
soccerrplyr soccerrplyr is offline
My Saabs: 1999 9-3vig clone 2000 9-3vig clone
i made my tool out of pvc pipe with cut slits. Then used a strap wrench to turn it. Total cost was 10-15 bucks for those
Old 13-03-09
Aaaaar...I hate my Saab. Replaced the pump, but still no fuel going to the engine. I keep hearing a clicking noise from the left-hand side of the firewall, right underneath the steering wheel; I'm thinking this click is the relay. *sigh* There's also a constant clicking noise from the fuel pump assembly. Car just doesn't want to start!!! Could this be caused by a faulty FPR????
Old 13-03-09
My Saabs: 1997 900S
Did you check to see if there's spark at the spark plugs?
Oh, and if your hose inside the pump falls off, you'll hear the pumping but the fuel won't be pumped out.
