Flywheel - SaabCentral Forums
Go Back   SaabCentral Forums > Classic Saab 900, 1979-1993 & 94 Convertible > Classic Saab 900 Performance, Mods & Tuning
Classic Saab 900 Performance, Mods & Tuning Covers Tuning & Performance modifications for the Classic Saab 900
Old 28-01-08
idiot_saabvant's Avatar
idiot_saabvant idiot_saabvant is offline
My Saabs: 900 T16V M88, 900 T16V 89SPG, 78 99 GLS
Default Flywheel
I'm looking for thoughts on lightening a steel flywheel, or at least having it balanced. Does one take the material off from the back side or does one mill the front were the clutch touches? I thought I read that one can remove about 2-4lbs from a stock steel flywheel.
pierre
Old 28-01-08
shaverjeff shaverjeff is offline
My Saabs: 1994 saab 900 turbo vert
I've heard it was safe up to 7lbs removed from a guy at thelocal strip. He seemed pretty knowledgable and was in the low 15's with a pretty much stock (other than apc) spg.
If you can I would say spring for the aluminum I think my overall weight on ym sd unit is 7lbs I think the stock job is amost 20lbs. It is a bit more prone to stalling but it revs up like a motorbike.
Old 29-01-08
yfs87's Avatar
yfs87 yfs87 is offline
I would say you have a shop pull the clutch locating pins off the front side, then face it a few times, then replace pins. 5-7 pounds would make a big difference.
On the road:
90 c900T16 cabriolet - red
91 c900spg - red
79 Porsche 911SC - red
Projects:
92 c900s 4dr - blue (on the backburner)
RIP:
93' c900s (drunk driver hit it)
90' c900s (deer found it attractive)
89' c900T (Friend crashed it)
88' c900T (parted)
87' c900T (parted)
89' c900s (parted)
My Bands Myspace
Facebook Me
Old 29-01-08
So if I face the front (clutch side) of the flywheel, it will not effect engagement of clutch? Several pounds would be nice to remove.
pierre
Old 29-01-08
NSE's Avatar
NSE NSE is offline
My Saabs: '83 T8 4dr.
I have read (by searching on SC) that you can safely take off 2kg - 3kg (4.5-6.5lbs) Anymore than that and you can run into drivability problems.
Here's a link to a photo and a little info: http://web.inter.nl.net/users/turbo-...e/flywheel.htm
Joe
My '83 T8 4dr project thread
Old 29-01-08
nutcase's Avatar
nutcase nutcase is offline
My Saabs: 1978 99T in black; 1983 99GL in Beige
Be wary of taking overall thickness off the flywheel, if its too thin, the clutch slave may have to over extend and pop
Photo Gallery
Old 29-01-08
GlenM GlenM is offline
My Saabs: Black 91 T16S Convertible TSL 220 bhp
Flywheels are supposed to have material removed from the back, ie. the side away from the clutch.
Old 30-01-08
TooMany2cvs's Avatar
TooMany2cvs TooMany2cvs is offline
Saabista
My Saabs: '90 900T16 3dr - For Sale!
They should remove it from anywhere they can APART from the clutch face, the ring gear and the crank mounting face.
Weight removed from the edge is "heavier" than the same amount of weight removed from the middle.
To give you an example of what CAN be done, these are flywheels for 2cv racing :-
1.8kg for the alloy one, 2.3kg for the steel one in the pic.
Standard is 6.5 or 10.2kg, depending on age...
Adrian
Soon to be living life on the road in an old VW
http://WhereverTheRoadGoes.com
Old 30-01-08
allessence allessence is offline
My Saabs: 1991 Talledaga Red SPG (Rosie)
Just run an alum one.
Okay, So I'm female and I love SAABs what is a girl to do?
Rosie: http://www.saabcentral.com/forums/sh...ight=Jennifers
Old 31-01-08
Wish I could run an alum one, but funds have not been saved for that. But here is what I did do: Got my flywheel done yesterday. Here it is before milling http://www.saabphotos.com/gallery/album571/saabfw and then after (clutch side) http://www.saabphotos.com/gallery/album571/saabfw_003 and back side with weight removed http://www.saabphotos.com/gallery/album571/saabfw_001. I got 1.4 lbs off
and could have taken more, but this is what I bought ($125 US). It was also balanced, but I do not have a picture of the holes that were drilled on the surface that the timing marks are on. So this should really help with engine spool up and minimze harmonic vibration through the tranny and crank (which could rob hp)
pierre
