$40 Short Ram Intake DIY - Page 14 - SaabCentral Forums
Go Back   SaabCentral Forums > Saab 9-3 SportSedan/Convertible ('04+)/Combi, 2003-2011 > Saab 9-3 SS, Combi & Convertible Performance, Mods & Tuning
Saab 9-3 SS, Combi & Convertible Performance, Mods & Tuning Covers Tuning & Performance modifications for the Saab 9-3 Sports Saloon/Sedan, Combi & Convertible
Old 15-08-11
bparker5512's Avatar
bparker5512 bparker5512 is online now
My Saabs: Turbo X MT VTune 0 Rev. 2
Garage
Originally Posted by SaabMick View Post
I'm not sure how protected the filter is, but the last cai I installed I also used a breather filter up in the engine bay in case I ran into any high water situation. It allows the intake to breath in dry air if the lower filter becomes submerged (again, I'm not sure how low the main filter is in your install). If you're not familiar with that type of filter, it's basically just a coupling that you would install inline with the intake tubing down to the main filter.
Other than that, I think you've done a beautiful job of fabbing the first cold air intake I've seen on this forum. Nicely done!
Another thought..
http://www.autoanything.com/air-filt...A2582A0A0.aspx
Originally Posted by lamber34 View Post
I just did this mod only I only got the filter 24.99 then the maf sensor pipe with the built in spot for the sensor pulled the stock off and put the new one on. Easy and good mod. Highly recommend mod
Pretty sure that'll throw a CEL.. Replacing the MAF pipe like that is a no no..
Old 15-08-11
lamber34 lamber34 is offline
My Saabs: 2005 9 3 arc
Default no cel yet
my car hasnt thrown a cel yet and is running great no uneven idle or anything until that happens happy with the mod. i replaced the pipe and postioned it directly into the old spot with exact same position. i will post pics later.
Old 15-08-11
Nocturne's Avatar
Nocturne Nocturne is offline
My Saabs: 2004 Nocturne Blue 9-3ss Linear
Garage
Originally Posted by bparker5512 View Post
Another thought..
If the pipe interior diameter is the same as stock, it won't throw a CEL.
2004 9-3 Linear Canadian touring package.
16" 10 spoke wheels, dual Xenon, sunroof, reverse parking sensors, auto wipers, homelink auto dimming mirror, heated seats, dual climate control, block heater.
Old 16-08-11
Garage
I know. It sounded like he used a universal MAF sensor pipe which I doubt is built to the same specifications.
Old 16-08-11
Jn2's Avatar
Jn2 Jn2 is offline
My Saabs: 07' 9-3ss Aero
dont forget the stock pipe is a D shape, not a O shape
JZW Aggressive tune, GS 3" downpipe, MPx Blow off plate, DIY intake, 18x8 Moda Md6's, TWM short throw shifter, Aeroforce Interceptor gauge
Old 29-08-11
Saabstory34's Avatar
Saabstory34 Saabstory34 is offline
My Saabs: 2006 Saab 9ł 2.0T Custom E85 tune by JZW
Garage
Any pics yet?
JZW Custom E85 Tune, JT 3" DP with 3" exhaust, Spec 2+ clutch, H&R Springs, Koni yellows, TSW Nogaro 19s wrapped in 245/35R19 Hankook Ventus V12 Evo, boost gauge, TWM Short Shifter
Old 30-08-11
Default Will post
Will post pics this weekend
Old 04-09-11
Wagon Wagon is offline
Banned
My Saabs: 490hp/580TQ (CF and Estimated BY ME)
What is the diameter on the piping a 2.8T? Basically the size of the piping that the filter attaches to.
Old 04-09-11
Jas86 Jas86 is offline
My Saabs: 2003 9-3 2.0t Linear
Is it possible to just cut and drill a spot for the the MAF sensor into a 2.5" pipe?
I'd like to preserve the stock airbox, if possible.
Old 04-09-11
Jn2's Avatar
Jn2 Jn2 is offline
See my post, which is 2-3 above urs...the stock airbox pipe is a D shape, not a O shape like a normal pipe
Old 23-10-11
micakaj123's Avatar
micakaj123 micakaj123 is offline
My Saabs: 07 9-3 2.0T 6spd JZW Stage 1
I finished my diy intake.
Used the stock box as a heat shield, still get that pshh sound.
Here are a couple of pics:
Old 24-10-11
j-y's Avatar
j-y j-y is offline
My Saabs: 2005 9-3 Hirsch
That is really creative... excellent job
Old 24-10-11
micakaj123's Avatar
Thanks man, i figured the stock box was made to fit the car so it would be easier then going completely custom
Old 04-01-12
Seppk's Avatar
Seppk Seppk is offline
My Saabs: 2006 Saab 9-3 2.0T
Just finished my intake...
45 Degree elbow
3-2.5" coupler
Medium Spectre Filter
Total: $48 at autozone
I made a pretty solid security system so the intake doesn't bounce around: zip tie tube to 'hook' mount from previous air box, pad contact areas with double-sided tape and squares of garage door bottom)
I really like the top end turbo sound but not sure If I like the turbo drone as I go a constant-normal driving speed. Is there a way to adjust the sound or will the MAF adapt?
ID:	27015   Click image for larger version
Old 10-02-12
micakaj123's Avatar
Sorry guys i broke the link to the picture for the heat shield.
Here is the pic again:
Old 02-03-12
rhymesayers90 rhymesayers90 is offline
My Saabs: 2003 9-3 2.0t linear
Garage
what did you use to cut the box with a dremel?? did you use any thing to clean up the edges?? your pic looks super clean and i like the look way more than the bsr heat shield. do you still get the louder turbo effect all the way thru the throttle??
Old 02-03-12
micakaj123's Avatar
I believe i used a dremel to cut the box or a jig saw. I went to Oreilys or auto zone and bought some of that black outside door trim that's primarily used to protect the edges of your door when opening them in case you hit something. That cleans up the jagged edges that the dremel makes, but i still lightly scraped and sanded the edges prior to putting the black trim.
The pshhhhh sound is definitely still there. It actually works as a heat shield as well, when i go for long or short drives the intake pipe is actually cold when i open the hood and touch it, as opposed to being hot as F when i didnt have the heat shield.
I didn't like the idea of throwing away the stock box because its made to perfectly fit and mount in that spot. Dont get me wrong, i like the BSR set up, but i was too cheap to spend that kind of money on something that just adds sound lol.
You may or may not have to shave some of the inside of the box out as well to create a better fit, but thats trial and error. Basically shave, if you want a better fit, shave more lol.
Old 02-03-12
Garage
i just got back from advanced auto parts to do a price estimation and just see if they have what i need. i saw all the same spectre parts youve got. do you have anything negative to say about the spectre parts? someone on another thread said to go with the aem cuz its better but its also 100% more of my money. does it make that big of a diffence do you think? also tell me if this parts list is correct. one 3" to 2-1/2" coupler, 1 45 degree intake pipe, one filter of my choosing, and some door trim material for the air box. thanks
Old 02-03-12
micakaj123's Avatar
Spectre parts are perfectly fine for an intake. I haven't had a problem with them at all.
Your parts list seems correct but it has been a while since I've done this. Im almost positive your right though.
You may have to force the 2.5" side of the coupler to the stock hose, but if anything thats better because it will be more air tight.
I think the door trim material is called door edge guard or something and has a glue like substance on the inside so it stays. You will need a hair dryer or something to make it pliable.
But its seems like your good to go!
Old 02-03-12
micakaj123's Avatar
Also, when jig sawing the stock box, try not to make the corners so sharp like i did because it will make putting the door guard on it a pain in the ***.
To make your life easier do it more like this:
