New gearbox parts... - SaabCentral Forums
Go Back   SaabCentral Forums > Other Saab Models > Saab 99 & 90 Workshop
Saab 99 & 90 Workshop Saab 99 & 90 Technical Forum
Old 24-01-08
ejenner's Avatar
ejenner ejenner is offline
Banned
My Saabs: 900 Carlsson, 99t, 99 T16, 900 t16 vert
Default New gearbox parts...
I'm just in the process of opening up the box for my 99 and noticed it does not look too difficult to change some of the bearing while I'm in there. Does anyone know what new rebuild parts can be bought for reasonable money - might as well change some bits as I'm in there!
Old 24-01-08
nutcase's Avatar
nutcase nutcase is offline
My Saabs: 1978 99T in black; 1983 99GL in Beige
Agree you should change a few of the more vulnerable bearings while you're in there. Layshaft bearings and pinion bearings are a must. Ask Boxman for advice on others
Photo Gallery
Old 24-01-08
ejenner's Avatar
Banned
You remember when you were in my garage the other day and we were talking about grooves in the layshaft... well.. took it out today and it's totally smooth, not the slightest notch in it!
Originally Posted by nutcase
a) Layshaft (countershaft) needle bearings for the 4 speed box up 1973-1981 (saab part number 8712382) is available through Bearing Supplies (Norwich) Ltd. 01603 891800 www.bearing-supplies.co.uk Part number K20X26X20 £6.11 each Recommended by Nutcase.
Any idea how many of these bearings one would consider ordering should one be repairing one's transmission?
Old 24-01-08
nutcase's Avatar
You jammy oik Apart from breaking the end off
Two
By the way, that engine was a bit wierd. 900 mounting brackets and a 99 waterpump cover
Photo Gallery
Old 24-01-08
ejenner's Avatar
Banned
No idea... birdie said there was something weird about the cylinder head as well. He wasn't specific though... something about manifold studs. I'm guessing this engine was taken from a 99 and transplanted into a 900.
Now what about my gearbox parts...
Old 25-01-08
nutcase's Avatar
Strange
Two
Photo Gallery
Old 25-01-08
ejenner's Avatar
Banned
I know... two of those bearings... but what else...?
Old 25-01-08
ejenner's Avatar
Banned
This is not a part number: K20X26X20
It's a size...! K 20 x 26 x 20
You can get it from millions of bearings suppliers... but it's a slightly unusual size so always available next day delivery... noone keeps it on the shelf.
Old 25-01-08
nutcase's Avatar
A lot of bearings part numbers are their sizes Makes life easier.
Just to (mildly, possibly) annoy you, I got the proper puller for the reverse and layshaft in the post today. Nice ebay bargain, didn't even notice it in the pic!
Photo Gallery
Old 25-01-08
ejenner's Avatar
Banned
lady luck was on your side chap!
It's actually quite easy if you've done it once. I gave up before because it was late in the evening and I didn't fancy any more work and I'd run out of leaverage on my homemade-puller. When I open up the 5-speed in a couple of days time I reckon it's going to much easier...!
Old 25-01-08
BIRDIEMANGO's Avatar
BIRDIEMANGO BIRDIEMANGO is offline
Location: AN ENGINEER CAN DO FOR THREE QUID,WHAT A FOOL CAN DO FOR FIVE...
My Saabs: 3 CLASSIC 900 SEVEN 99'S
WELL ,GO ON THEN.......APART FROM,THE HUB PULLER FOR THE 99 TURBO FRONT DISCS...........AND THE LAYSHAFT PULLER..............WHAT OTHER GOODIES WERE IN THERE
AN ENGINEER CAN DO FOR THREE QUID,WHAT A FOOL CAN DO FOR FIVE....
Old 26-01-08
nutcase's Avatar
Not identified it all yet, but:
A bearing installer/remover (basically a punch) for various gearbox bearings and steering knuckles
A gearbox drain plug tool, not for the '75- 99.
An alignment tool for rear caliper pistons.
Some kind of bearing drift, not for '75- 99.
A couple of possibly shaft pullers, not for '75- 99.
A couple of workshop made bearing installers (water pump puter-inner as one is labelled ).
Diff bearing ring puller, engine chain gear puller, front wheel hub bearing puller.
Some kind of podger for a 99 gearbox. Doesn't appear to be an official tool.
And a Churchill (as who made some of the other tools) thing. Doesn't appear to be an official tool, looks more like a centring bit for a lathe.
And a few other random bits like a seal, some rollers from a needle bearing, and and engine lifting eye.
An interesting "haul"
Photo Gallery
Old 26-01-08
ejenner's Avatar
Banned
Got me needle bearings..
