| Saab 9000 Workshop Saab 9000 (1985-1998) Technical Forum |
Put a new battery in and started it right up and ran for 5 minutes
. Then it died. Everything was responsive. The battery is brand new. I did get the ABS and Brake lights come on. It displayed 8.7 volts the whole time. No reading from the alternator. (like someone said i should have) the Radio read "3555" no idea what that means. Tried to start it again and no response. you can hear it trying to catch. This was the trend before i changed the battery. Ran for 5 minutes then died. Foot on gas pedal made no difference.
If the Army and the Navy were to look on Heavens scenes, they would see the streets are guarded by United States Marines. Last edited by Giomeister; 23-01-08 at 03:34 PM. |
| Sponsored Links | ||
Advertisement | ||
Radio displays the wrong code was entered... Push and hold the band button for about 5-10 sec to clear and re-enter, you might have to leave teh car on accessories for a hour to clear do to exceeding teh amount of wrong codes entered (3)..... Does the car turn over? If so and doesn't start you could have a elec. problem or fuel. Any lights on on the dash?
Need more info to help better..... Josh |
If you have anyone close to you with a known good DI, then try that first. Also, could be dirty fuel filter.
Klim
The only way to measure true happiness is in terms of boost 270hp/396ft/lb. Maptun stage 3 ECU, JT 3 inch downpipe, cat and the rest of exaust, k&n filter. |
I have power all lights on the dash and internal lights are on. I try to start it you can hear it trying to catch but it does not turn over. When i had it running it was displaying 8.7 volts while running is that the alternator?
The DI is black it was swapped out from the original red. I am thinking he did not test it. not to mention the DI wires (with the white clip) is loose and does not have the plastic slide i have seen on other harnesses. the vacuum lines are loose in a few areas as well. I will replace the bushings and the air intake valve. I plan on doing air filter, fuel filter, and plugs and fluids. Basic maintenance i know...but saabs are tempermental. So after this i will diagnose to see if the fuel pump is working. Testing the DI i am not so sure about.
If the Army and the Navy were to look on Heavens scenes, they would see the streets are guarded by United States Marines. |
DId you cycle the dashboard computer when you started her? Mine will show around 9V even if I press R button. You just have to cycle it(see temperature, average mpg etc). If it still show 9V then something wrong with your charging system. If it shows more like 13v then you are OK.
So, wait, does the starter and the engine turn, and the car doesn't catch, or the starter actually doesn't rotate? Klim
it sounds the same way when i tried to restart, turn the key and it starts. Then try again, and hear it try to start, but nothing.
I am not sure how i read the Alternator amps.
| Sponsored Links | |
Advertisement | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
