60,000 mile tune up is $730... Holly cra$ man - SaabCentral Forums
Old 15th January 2008
Highnndry Highnndry is offline
My Saabs: SAAB 04 9-3 ARC
Default 60,000 mile tune up is $730... Holly cra$ man
My car is approaching 60k miles and I called Santa Ana SAAB to get an estimate and they told me it's $730, just what the heck do they change in there that it costs so much?
I hope it is worth it, I also think that they are charging me for the loaner car that they provide. I wonder how much is the built in cost for the loaner car, at least I hope they give me a SAAB loaner, or I'll be bit$hing and moaning again for the next 1 year.
Will they do somwething about my key, because lately the key doesn't work properly, it doesn't open the door all the time. It is so embarassing when I have to manually open the door and the alarm goes off. It's been happening quite a lot almost every other day or so.
Cosmicflash Cosmicflash is offline
My Saabs: '09 9-3 SS Aero XWD
I'd do a search here as there was thead in the last several days on this.
Unless they are doing plugs, air filter, cabin filter, oil change, serpentine belt, and tranny fluid, although still high, just give them a list of these things and see what that price would be.
These posted recommended services are absolutely outrageous. I guess people pay them though.
03' SS Linear Cosmic Blue, 109k mi., gone
06' SC Aero Auto Fusion Blue, BSR tuned, 94k gone.
09' SS Aero XWD Auto
Carbon Gray, Black Premium Leather, VTuned, 30% tint.
SMHarman SMHarman is offline
My Saabs: '03 9-3SS Vector
The list of what should be covered in the 60k is in the handbook. Anything above that is not scheduled maint, but the dealer creating work and money.
The key. Did you ever get yours replaced as part of the campaign. If you key number (you can see it when you pull the metal key out) starts with a 236 or 231 or something then it is an old one and liable to go faulty.
http://www.saabforums.com/recalls-an...312429/TSB.htm
Have you ever replaced the battery in the key?
I have not replaced the battery in the key as it is less than a year, I bought the car in March of 07. The number starts with 538 on mine.
lurkydismal lurkydismal is offline
My Saabs: 2009 93 SC, 2000 93 Viggen
I just dropped off my 2006 93 Combi (2.0T) for the 24k KM oil-change...C$480 +tx! Now that was a lot more than oil change, but I asked they scale the service back to oil change, rotate tires and check brakes. I can hardly imagine at that service interval on a practically new car it needs more than that.
Upside, they gave me an 07 93 SS as a loaner, I got to experience the newer dash config and would have to agree that interior noise level seems improved (although I am comparing to an SC, which I think may get more cabin noise because of the wagon)
LD
Aspen Aspen is offline
My Saabs: former SAAB owner
I hope they did more than check the brakes for that price. An oil change at my dealer is C$125, so $40 to rotate the tires leaves $315 to check the brakes. Even a brake clean and lube for all four should be less than that.
They were going to charge me $480, I told them to only change the oil, rotate tires and check brakes. I am expecting less than $200, unless the brakes need work and they shouldn't need pads/rotors.
jmcgoblue jmcgoblue is offline
My Saabs: 2007 9-3SS
Just for reference, the local dealer in Atlanta charges $83 for an oil change, + $10 for the tire rotation/brake check (though the latter charge is w/ a coupon...not sure what the regular charge is).
Just got the call, they charged me C$140 + tax. As suspected, my brakes were fine, all of the other "stuff" they wanted to charge me for was not necessary.
Back to my issue , is $730 reasonable for the 60K tune up. Can this be done somewhere else? I'm worried about the belt tensioners and what not.....
Nickshu's Avatar
Nickshu Nickshu is offline
My Saabs: 07 9-3 SportCombi 60th Anniversary
Not uncommon. A friend just had a 60K tuneup on his Chevy SUV for $950. Routine stuff only. Hourly labor + parts adds up quick these days.
This is not a Saab-only phenomenon. A good alternative is a non-dealer independent Saab shop. Prices usually more reasonable.
Nick -- Saab-less for the first time since 1991.
Current cars: '13 Volvo C70 retractable hardtop; '13 Subaru Outback 3.6R SAP; '64 Corvair Monza Spyder (factory turbo) Convertible
Prior Saabs: 86 9000T, 91 9000CD, 93 900S, 95 900S, 07 9-3 SportCombi 60th Anniv Edition
Just drop off the car and I thought during the 60K tune up they fix the tensioner or something but the tech says no. So, it's basically oil change and top off fluid with spark plugs and filters, still it's very expensive.
I got a loaner 07 2.0T and man it looks cheap, it looks cheaper than my 04 2.0T. I can hardly read the radio display because of the reflection. They did add the volume level that I don't have on my 04, wish there was one.
freed929 freed929 is offline
My Saabs: 2007 9-3
I took my wifes 9-3 in for the 5k service and they gave me a loaner SUV, why I don't know only took an hour and a half. When I went to pick it up I was reaching for my wallet and the service manager said don't worry about it we got it. I thought wow this is what makes me happy to have bouoght a SAAB. I guess that is a good plug for INDY SAAB
BKNJ BKNJ is offline
My Saabs: 2004 9-3 SS Linear
freed929, All new Saabs (US) come with 3 Year, 36 K free maintenance. Effectively 2 oil changes and 30 K maintenance. It was nice that they gave you a loaner on a short service visit like that.
Bryan
cavedudejeff's Avatar
cavedudejeff cavedudejeff is offline
My Saabs: 2005 9-3SS Linear
Uhm.... why are you complaining...? You went to the stealership so chances are you've never changed oil in a car yourself and you assume going to a dealer over a corner garage means better service just pay the 700+ bucks and be happy about it.
Old 16th January 2008
Cave,
What help is this???
I've changed the oil in my cars numerous times. Our Saab 9-3SS are not the same.
The dealer can often offer good competitive services...
Well lets just say that threads like this pop up like weeds here on the forum with everyone complaining about how expensive the services are... when the dealership has a sign up in the service area that states "Hourly Labor rate - $100+ hr" what do you guys seriously expect... anyone thats ever been in any type of car accident knows that insurance companies pay 35 per hour labor which is the industry standard rate for mechanical work on autos.
And as for the dealership offering competetive services... I'd love to know where exactly is this because here in NYC i have been to every single stealership within a 50 mile radius (which is quite a few) and they have all been staffed by techs that are absolute retards. If it wasnt for the fact that all these issues have been warranty related and SAAB requires me to go to a stealer... i would never have anything done by them....
I mean come on people 100 bux for a oil change with MOBIL 1? the oil will run you 25 bux at retail plus filter comes out to around 32 bux... that means youre paying the stealership tech 68 beans to lift your car, pull the oil plug, sit around scratching his balls for 10 minutes while the oil drains, replace the plug, lower the car, replace the filter, and pour in new oil, all of which takes 15 minutes or less.
JonV JonV is offline
Saabista
My Saabs: 03 SE 5 Spd
Duh! Free service for 36K.
cjhutch's Avatar
cjhutch cjhutch is offline
My Saabs: '02 9-5 Aero Wagon BCB St. 1
I have done the 60K mile service on my car. The hardest part of the whole thing was changing the cabin filter. Dealer here in ATL wanted $1150 to do the 60K mile service. I said no thank you and bought the spark plugs, oil filter, and belt from them. I got all my fluids from Autozone and air and cabin filters from thesaabsite. I saved myself around $900 doing it myself and it only took me about 2 hours from start to finish. It's really easy and if you can't do it yourself it's a job that even a mechanic at a tire place can do for you. I know at the Goodyear place down the street from my house they will do the labor for $50 on changing spark plugs and fluids so even if you can't do it yourself buying the parts from the dealer and then having someone else do the work will save you a LOT of money.
brianl703 brianl703 is offline
My Saabs: 2006 93 2.0T
Body work costs less than mechnical work, according to my insurance company which in this area pays $45/hour for body work.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
