best place to get intrax springs? - SaabCentral Forums
Go Back   SaabCentral Forums > Saab C900, 1979-1993 & '94 Convertible (C=classic) > C900 Performance, Mods & Tuning
C900 Performance, Mods & Tuning Covers Tuning & Performance modifications for the Classic 900 (C900)
Old 13th January 2008
mikewitdaspike's Avatar
mikewitdaspike mikewitdaspike is offline
My Saabs: none, but it's coming again...
Default best place to get intrax springs?
i thought i saw them on ebay in the past for like, $200, but i don't see them i've decided i want them, if for no other reason than for the looks i went cruising on the main strip last night, and every other car was slammed to the ground, i felt like an SUV but either way, i do want the intrax springs, anyone know where i can find them for under $300?
2002 Mini Cooper S
1999 Ford Ranger
Stuck in Korea till Sep. 2012
EngSaab EngSaab is offline
My Saabs: 92 c900t & 91 9kt
Default summit racing
has them for 230 plus shipping.
Good luck
SWEET!!! thank you!! with that price, they might be ordered tomorrow
2002 Mini Cooper S
1999 Ford Ranger
brownie brownie is offline
My Saabs: 1985 900 turbo
I've had mine for a few years and still like them a lot. You may require a stiffer shock to dampen the stiffer spring, but you could wait and see for yourself. I have Intrax and Bilsteins. Don't forget to cut off one bulb from your front bump stop.
cut one bulb... got it will it rub if i do that?
2002 Mini Cooper S
1999 Ford Ranger
Old 14th January 2008
scubasaab's Avatar
scubasaab scubasaab is offline
My Saabs: 87 900t CV
The lowering springs might cause rubbing. The reason to cut the bulb off the bump stops is because you will constantly be bottoming out against the stop.
Good luck, madman!!
Anyone seen my Turbo Encabulator
Good luck, madman!!
i'm just trying to help myself stay away from any more curbs
2002 Mini Cooper S
1999 Ford Ranger
IronJoe's Avatar
IronJoe IronJoe is offline
My Saabs: '87 Airflow Convertible, '08 Turbo X SC
Garage
Seems like some have this issue, and some don't. I also have the intrax + bilstien combo (trimmed the fronts for more drop) but I never had to cut a bulb off of the front bump stop. Interesting.
- Current project
- 400bhp, Eurotuner Magazine Feature Car -
- Sold
- Sold
scubasaab's Avatar
Just a suggestion mind you... S-L-O-W D-O-W-N
Joe, do you mean you cut the spring to drop the front?
I put Intrax in the rear so far and the front is goin in by late spring, but I'm shimming them to about half the drop and I'm running Billstein Touring dampers.
that too... though i have found i enjoy cruising at about 35mph but only on cruise night, lol
2002 Mini Cooper S
1999 Ford Ranger
IronJoe's Avatar
Garage
yep I cut a half coil off the fronts... Probably will do some more
- Current project
- Sold
- Sold
RM '92 SPG's Avatar
RM '92 SPG RM '92 SPG is offline
My Saabs: 1992 900T 3dr
Here's a recent dirty photo. This is the intrax set with about a 3/4 coil chopped in the rear, and a little more in the front. The tires are 195/50/16. Nothing bigger would work well. I cut the bump stop initially, but found the rear tires would rub the inside of the wheel well, and put stock level bump-stops back in. There's only about 1.5" of spring travel in the rear until the stops are hit.
Intrax are quite a decent spring I've found, and they aren't very expensive, so cutting them up isn't too hard to stomach.
Pap's Avatar
Pap Pap is offline
My Saabs: 1985 900T16
I am also considering Intrax for next summer. Ebay HAD them, but not anymore it seems.
RM, that is a nice drop, i'm sure it handles nice too. BTW, did you get my pics of the K&N?
IronJoe's Avatar
Garage
Here's a pic of mine with intrax. Due to the fat wheel arches I've only got about a fingertip gap at the front tires. The rear tires rub on the arches with more than two occupants. Worth it though
- Current project
- Sold
- Sold
Green9kAERO's Avatar
Green9kAERO Green9kAERO is offline
My Saabs: 1991 saab 9000T, 90 900T
holy **** joe.. that vert is free-kin amazing.....
JP
jprop jprop is offline
I have a used set. PM me.
Jeff P
RM '92 SPG's Avatar
It's not bad, corners really well, but it's really quite a rough ride. I saw the picture you sent, I sent you a PM back, did you get it?
Old 15th January 2008
SteveMcqueen SteveMcqueen is offline
My Saabs: 93' 900 Turbo 00' Viggen
That looks bad. Was it you who wrote the SPG panel install guide? Thanks and nice car.
Old 16th January 2008
RM '92 SPG's Avatar
Bad as in good or bad as in ......bad? Yeah, that write-up is my brain-child. Took way too much time. I'm glad people are getting use of it though!
Old 27th January 2008
edwinhess edwinhess is offline
My Saabs: 87 Saab 900 soon to be Spg
Im buying springs in the next couple of days and was looking at getting these
http://www.saabperformanceparts.com/item192.htm Anyone running them? I see people with the brad springs, and the Intrax, but not the springs from SPP.
Any info would be great!
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
