02 Aero- Xenons VERY dimm - SaabCentral Forums
Old 11-01-08
Aero1's Avatar
Aero1 Aero1 is offline
My Saabs: 2002 Aero Sedan Blk/Tan
Default 02 Aero- Xenons VERY dimm
Hey there guys, I've had my car since 02, and the past year or so the xenon's have been so dim its almost un bearable to drive without the high beams on at all times. I was wondering if any of you guys have had this problem, or what you may think would resolve it. I was thinking either it's the bulbs or maybe the ballasts were bad? I took the bulb out to look at it and the little xenon chamber in the middle of the bulb looks white, not clear. I want to replace them with some Osram 6000k D1s'.
Thanks in advance!
Past-'02 Blk/Tan 9-5 Aero blown motor;
'00 Blk S4- Stage 2 Toatled
Present-'00 Nogaro S4 Stage 3 456WHP;
'97 Blk/Blk 900SE Coupe
Old 11-01-08
saabchilten's Avatar
saabchilten saabchilten is offline
My Saabs: '96 900SE 2.0t Convertible a.k.a. Aeron
unbearable to drive without the high beams on? it's the same output with high or low beams, just that a shutter adjusts where the light is thrown. i suppose they might be worn in some way, but normally the lights flicker when they are about to die.
"and when the sun shines...you can peel off the rest of your inhibitions"
Old 15-01-08
Aero1's Avatar
Any help??????
Old 15-01-08
SectorNine50's Avatar
SectorNine50 SectorNine50 is offline
My Saabs: 2000 9-5 Aero 5-Speed
Do they seem aimed correctly?
2000 9-5 Aero 5-Speed Silver/Black
Upgrades | Open Intake | Poly Trans Mount | Hub Braces | Sub-frame Brace (Broken) | Forge 007 | FMIC | Bilstein HD Dampeners | 3" CTI Cat-back
Old 15-01-08
Originally Posted by numbersix
Are the headlights aiming correctly?
Erm... Is there an echo?
Old 15-01-08
numbersix's Avatar
numbersix numbersix is offline
My Saabs: 2012 Traitormobile
Wow, gee, sorry about that.
Traitormobile
...be seeing you.
Old 15-01-08
woywitka's Avatar
woywitka woywitka is offline
My Saabs: '87 900 T16 vert, 911 SC,914,W123 Diesel
what colour are they? They turn pink when the bulbs die.
Fun times:
Classic Saab 900 Turbo Convertible, Porsche 911
Old 15-01-08
Haha no worries, the connotation of my post wasn't was I wanted it to be. I was just kidding around.
Old 15-01-08
That's not always true. My dad's just got really really dim but stayed the same general blue.
I can't imagine that both bulbs would go at the same time that soon! They are supposed to have 8 year lifes.
Old 15-01-08
B~P's Avatar
B~P B~P is offline
My Saabs: 2003 9-5 Aero
if the DRLs are active then the life cycle of the xenon bulb is probaly halved. which means for 2002 to 2004 cars the bulbs are likely not as bright as they were when new. i replaced both of my xenon bulbs and noticed a huge improvement in brightness.
Old 15-01-08
Ahh good point, forgot about DRL's. I disabled mine so I never think about them anymore...
Old 15-01-08
woywitka's Avatar
good to know then.
Fun times:
