b201 ticking/rattling noise - SaabCentral Forums
Old 07-01-08
ludichris001's Avatar
ludichris001 ludichris001 is offline
My Saabs: 89 900 EMS, 90 T16 900i, 2x 93 900i's
Question b201 ticking/rattling noise
i have had this problem since the engine was in my old 900.
when its cold the engine is almost silent but as i warms up there is a ticking coming from inside the valve cover.
i have done valve clearances about 6 times so far and tried a different cam but the noise is still there.
i have also noticed that the valve clearances go out of specs after about 500 kms but only to their previous values.
the noise seems to get louder and more ticks begin as revs increase.
i am positive that the chain guides are a bit worn but it sounds more like a tappet noise.
and also if push hard on the cam followers with my thumbs i can open each valve, should i be able to do that?
any suggestions?
Old 08-01-08
RickyS RickyS is offline
My Saabs: 1986 C900i 8v flat front
That is unsual for an 8v. The valve clearances rarely go out of spec even after high mileage. My last C900 had 180000 miles on clock, and was still in spec.
What mileage has the car done? How did you do the valve clearances? Did you add shims?
Flat front C900 - the original classic 900
