coilovers... - SaabCentral Forums
Old 05-01-08
99jettwolf 99jettwolf is offline
My Saabs: 99 Volkswagen Golf, 98 Saab 900 vert. DD
Default coilovers...
Are there any coilovers available for the NG900? i searched and searched and cannot find any. i'm not really looking for handling or performance, im just looking to be low.
the only pic involving the saab.
Old 06-01-08
wkndracr wkndracr is offline
My Saabs: 95 900 SE JSP stage 3
http://www.genuinesaab.com/catalog/product_info.php?cPath=56_28&products_id=466
only for the front, and not for street. otherwise i think intrax has the lowest drop.
Old 06-01-08
Viggen_93 Viggen_93 is offline
Banned
My Saabs: 99 Saab 93 , 02 93 ,03 95 AERO
intrax? where can i get those kind. i want my saab to be slammed.
Old 06-01-08
neomagus00 neomagus00 is offline
My Saabs: 2K 9-3 Conv, Stage 3 HW
intraxsuspension.com is probably a good place to start... it does seem a little out of date, but still useful, and it has a 'dealers' link
Old 06-01-08
01Brian's Avatar
01Brian 01Brian is offline
My Saabs: 2001 9-3 2.0L Turbo
http://store.newlevelmotorsports.com/insute.html
Intrax lowering springs.
Just find the Saab Models Lowering Springs.
Old 06-01-08
i think i would at least go with a strut and spring because the car has almost 100k on it. no?
sucks that they dont make any decent sets of lowering suspension.
Old 06-01-08
Bummer 9-3 Bummer 9-3 is offline
My Saabs: '99 9-3 SE HOT
If i was to get Intrax lowering springs what are good struts to run with them?
Old 07-01-08
pade900's Avatar
pade900 pade900 is offline
My Saabs: Saab 9-3 Viggen
Koni or Bilstein.
Personally I can recommend Konis, had them on two Saabs now and they are simply great. Konis are adjustable while Bilsteins are not.
But either way both are good choices.
Why do you want to put on a open air intake if I may ask?
Powerwise the stock intake with stock paper filter flows more then enough air for +400hp
http://www.garaget.org/?car=61
Old 07-01-08
Tweek's Turbos Tweek's Turbos is offline
My Saabs: 07 9-5 Combi, 99 9-3 Viggen, 85 900 SPG
Since you have a 'vert I would read this
http://photo.platonoff.com/Auto/2006...rax_vs_Eibach/
And think really hard about those intrax springs.
Old 07-01-08
Yea. Thats why im wondering about coilovers. I know on my vw golf i have kw v2s and they ride nice and stiff. The only thing i dont like is the fact that i have them cranked down all the way and they are still not low enough for me. This spring i think im just going to take the helper springs and rear perches out on the golf to go a little lower even though it is going to compensate the ride quality.
As far as the saab, i just wish there was something that would enable me to slam it and raise it if needed.
Old 07-01-08
The only coilovers are for the 9-3 which are slightly diff, and only made for the front. If you have an unlimited budget they could be made for your car I'm sure.
Old 08-01-08
pade900's Avatar
A Swedish company called Sellholm Tuning makes coilovers for the og9-3 but the price is unfortunately off the scale.
Only height adjustable Sellholm/Bilstein are around $4000,- and the top model with Proflex Evo 1 struts, 3-way adjustable with an external gas reservoir and double spring are +$7500,-
There also might be something else in development so who knows, maybe there will be reasonably priced coilovers for our cars in the near future
Old 08-01-08
wait... is that an "i know something you don't know" smile?
Old 08-01-08
crazybrightbrightman's Avatar
crazybrightbrightman crazybrightbrightman is offline
My Saabs: viggen
the reason there are no coilovers is down to the suspension design. most cars have seperate front hubs and suspension legs with the sterring via the hub. the 9-3 has a complete leg with sterring half way up the leg mean that any coilovers would have to have a complete hub assebly included and find a way around the steering problems. as for the rear it would be a tight fit to fit a coilover unit in place of the original shock. also the rear axle is designed to have the springs inbound and the axle flex a ceratin amount. fitting coilover where the shocks mount would alter the axles movement. in short you can only really get springs and shocks as the suspension is of a flawed design to begin with.
Old 08-01-08
Shirozina Shirozina is offline
My Saabs: 2002 9-3 aero 5spd 3dr
- so very true. Ruined a potentialy great car - everything else was going for it but the utterly awful GM based suspension crippled it at birth and no amount of modification can truly remedy it.
2002 9-3 Aero 3dr 5spd
Old 08-01-08
Big Pat Big Pat is offline
Not to mention that the shock tower is not built to resist the strain of both the shock and the spring - you'd need to either beef up the tower (and make it bigger at the same time - it'd be a tight squeeze up there) or be prepared to face the consequences...
Unfortunately, were are stuck with a non-optimal suspension geometry. However, something can certainly be worked out - Vauxhall won the BTCC with a Cavalier in 1995, and the Saab is very closely related to that car. I wonder what they used there, as the rules did not allow the basic design to be replaced altogether...
Old 09-01-08
NickTaliaferro's Avatar
NickTaliaferro NickTaliaferro is offline
My Saabs: GenuineSaab.com
I have been working for a while to get a nice suspension under My vig in track, street and drag use. Finally just took time to put the correct rears in yesterday.
It was apparent early on that it needed lots of help to autocross effectively. It started with more sway bar which works to a point that it carries the rear tires. Next is more spring rate. I tried front first. For drag it needs lots more rear rate but no so much front.
When I have more time I will do a long write-up on trolltuner.com In short the car is finally balanced and feeling like it should.
Here is a pic of the track/drag setup. The rear is a touch higher and firmer to keep it from squatting during acceleration. The front is adjusted as low as you can drive and not rub.
Best part the whole setup is cheap. Next is to get some custom valved Konis up front.. Thats maybe not so cheap.
More pics here : http://genuinesaab.com/gallery/VigSuspension
Nicholas Taliaferro GenuineSaab.com Since 2001 and nobody could spell Tali... | TrollTuner.com
2.0 GOOSE 500whp + 8500rpm = 11.06 @125 in -09 on a gt30 and stock gears
E85 Viggen 488whp / 440wtq 12.43@114 | Nordic/GS E85 9-3 SS Aero 317hp / 350ftlbs | -72 v4 Wagon 95 120hp <The most fun of all
Old 09-01-08
looks good. i just wish there was a way to be slammed. oh well.
Old 09-01-08
John Z Williams's Avatar
John Z Williams John Z Williams is offline
Vendor
My Saabs: b234-E85-10.59@138.57mph
Take a look at mine with voxtland springs and koni adjustables.
John
Old 09-01-08
combination of any of these spring kits, plus a body kit, will make it look lower than it actually is... bigger wheels, maybe pushed towards the outside of the wells, might help with the illusion...
