ACC: Normal vs. ACC: Lo Temp - SaabCentral Forums
Old 20-12-07
02BrnfrmjtsAero's Avatar
02BrnfrmjtsAero 02BrnfrmjtsAero is offline
My Saabs: 2002 9-5 Aero Wagon MT & 2008 9-5 SportC
Default ACC: Normal vs. ACC: Lo Temp
Yesterday I was playing around with my climate contol and held down the econ and off buttons at the same time. My SID then read ACC: Normal and then if I pushed it again it read ACC: Lo Temp.
What do these two settings mean/do?
Thanks for your help.
Old 20-12-07
walmark's Avatar
walmark walmark is offline
My Saabs: 9-5 SE Wagon '00 155K
ACC Normal:
Climate control will use A/C compressor all the time when the temperature is above 41F. This is to dehumidify incoming air.
ACC Lo Temp:
Climate control will use A/C compressor all the time when the temperature is above 55F. This will save gas by enabling ECON mode (compressor off) in higher temperatures than normal. May lead to fogging if hi humidity/rain and temperature below 55F
Old 21-12-07
Thanks for the reply.
