Fog Lamps Inquiry - SaabCentral Forums
Old 16-12-07
Field93 Field93 is offline
My Saabs: '04 93 Linear
Default Fog Lamps Inquiry
Hey, I'm new to the forum. I've got an '04 linear and i'm looking to install fog lamps. Does the plastic that covers that particular space come out with ease? Must it be cut? Also, I noticed that the fog lamp button is present by the other light controls. Does this mean that all the wiring is in place? Has anyone had any issues with installing fog lamps on a linear? Any input/advice will be much appreciated.
-Field93
Old 16-12-07
SMHarman SMHarman is offline
My Saabs: '03 9-3SS Vector
I have not done it but the work on the fog lamp locations is pretty easy. You need to make sure you have the harness there. I think it was still around in 04 but they decontented it in later years.
You also need a whole new headlamp control switch, one with the button for the front fog lamps.
Old 16-12-07
JonV JonV is offline
Saabista
My Saabs: 03 Vector
You said have the foglight switch, that means you havee the harness. As I recall that changed in 06.
You can get the directions here:
http://www.genuinesaab.com/psi/files/ss93foglights.pdf
Get the lights from Genuinne Saab and they'll be more than helpful.
Old 16-12-07
Thanks a lot guys. Also, what's the price range I'd be looking at for all this?
-Field93
Old 16-12-07
Cojoroh Cojoroh is offline
My Saabs: '04 Saab 9-3 Linear MT
i'll go ahead and tell you, it's not an easy install. i think you're technically supposed to take off the entire front clip, but i was somehow able to do it without taking it off. it's a very tight squeeze to remove the plastic covers and install the housing without scratching the area, but it can be done.
Old 16-12-07
sigurd sigurd is offline
My Saabs: SAAB technician
Foglight install is a pain in the *** if you don't already have it. It's easy to pull the fnt bumper but the pain is getting the old covers out without breaking or scratching things. Good luck. I would deffinatly reccomend pulling the fnt bumper.
Old 17-12-07
Saabista
My Saabs: 03 Vector
-Field93
check at genuinnesaab for the price.
