Tried to get in car this morning and the key fob was not unlocking anything- doors or trunk, and pressing any of the buttons had no effect. I resorted to using the key itself to unlock the driver door and then the alarm goes off. I put the key back together and started the car right up. No problems. Got to work and pressed the key fob to lock and set the alarm and it all works now. Even unlocked and relocked it to be sure.
Is the battery going out on the key fob, or is there another issue? If it is indeed the key fob battery, any problems with simply putting a new battery in it and being good to go?
The state that separates its warriors from its scholars will have its fighting done by cowards and its thinking done by fools -Thucydides |
| Sponsored Links | ||
Advertisement | ||
I believe there is a function on the remote whereby if it is pressed a number of times away from the car i.e. when it does not open the car, then it is locked out until it is placed in the ignition.
This feature is to prevent thieves robbing the keys and walking around a car park randomly pressing the unlock to see which car opens. A similar thing happened to my keys a few Months ago but has been fine ever since. |
^^ what he said. It's also a simple task to change the Battery, just pry open the fob with the key and drop in a new one...watch polarity.
I have ESPN
Who knows, the alarm could have tripped overnight and I didn't know it, or I could have been too far away when I started mashing the fob buttons. Quote:
And yes i know there is a fix by buying the parts, I just shouldn't have too |
If you push the "Customize" button and go to system settings, you can change the alarm type. From Full Alarm to Door Alarm (Your key will work even if the alarm goes off.) |
When the alarm goes off or comes on ???
as is the alarm is "tiggered"
So if the alarm is triggered, and you want your remote to still work, set it to door only. If you want it to be so you have to take the key out and open the door, and start the car to get the alarm off, put it on Full Alarm. |
Any Time. *10 Caracter limit FTL*
That means someone could smash a window, rob & trash the cahoonas out of everything inside and the alarm won't go off unless the scumbag opens the door.
damn. seriously?
Its crazy that i have to stick the key in the ignition if my car alarm goes off. How come all other cars i owned, if the alarm went off, i could just hit the button on my remote to turn it off? |
-set alarm -hit trunk button -open trunk to set off alarm -see if remote will turn off alarm... |
I don't know how the Saab one works but in my simple mind, the door sensors activate when the door is opened (when the interior light comes on). If the door is not opened, the door sensor does not activate. There is no window sensor, rather a movement sensor inside the cabin. If the window is broken the movement sensor is activated. If not when the window is broken but certainly when someone reaches in. The movement Sensor can be switched off if you decide to leave the dog in the car when you go shopping and want to lock the doors. May well be wrong but that is my understanding. |
My alarm has gone off several times and the remote has always worked to disarm it. I can't imagine it working any other way.
My '03 manual says: Switching off the alarm if tripped If the alarm has been triggered (direction indicators flashing and horn sounding) it can be turned off by pressing one of the buttons on the remote control or, if you are sitting in the car, by turning the ignition to ON (see below). |
| Sponsored Links | |
Advertisement | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
