Ugh. Depressing. - SaabCentral Forums
Old 08-12-07
TheRedBaron's Avatar
TheRedBaron TheRedBaron is offline
My Saabs: 1990 900 turbo
Default Ugh. Depressing.
Well, the other night it snowed here, and it wasn't too bad, until I got into my neighborhood. It was about 30-45 minutes after it had gotten dark, so the bottom layer of slush was just starting to freeze, making it basically a big ice rink. I was going slow, but there's one turn I had to make that slopes downhill, away from the turn. Well, as luck would have it, it was also one giant ice patch, and I curbed my left front wheel Pretty treacherous, my roomate did the exact same thing in his jeep an hour later when he came home. The area was covered in sand the next day, I guess it is a "problem area" for ice in the neighborhood.
Anyway, now I've got some massive positive camber. The lower control arm is seriously bent, but luckily it seems to have taken the full brunt of the impact. The tie rod, spindle and upper control arm (thank goodness for that one) seem to be straight and true. Unfortunately I don't have the tools required to replace the lower control arm, nor do I have the time to go to the junkyard and then fix it this weekend Which means I have to take it to the shop. Luckily the place is close enough that I can drive there going 15 mph (there's quite a shimmy in the front end).
Ugh, and all this right before the holidays I'm pretty crestfallen, just needed to vent. Thanks for listening!
The faster you go, the more you see.
Old 08-12-07
nutcase's Avatar
nutcase nutcase is offline
My Saabs: 1978 99T in black; 1983 99GL in Beige
Bad luck This is why I agree with those who say not to reinforce the A-Arms. A lot cheaper to replace than the front of the body
Sure you don't have the tools? Two bolts, five nuts and it's off. Reverse to replace.
Photo Gallery
Old 08-12-07
Well those nuts on the bracket can't come off without a long socket (which I don't have).
Then there would need to be an alignment done anyway, which I can't do myself. Also, I'd rather have a more experienced set of eyes looking at the suspension parts, just to be safe, and make sure I haven't compromised anything else.
I suppose I could go to the junkyard later, and butcher some poor car trying to get an A-arm off with vise-grips and a hammer, and see what happens. But last time I was there, there was narry a c900 to be found (athough their stock does rotate fairly quickly).
Maybe I'll try it!
edit - I also don't have the 19mm or whatever size socket/wrench is needed to get off the ball joints/tie rods. maybe my buddy does, I'll call him.
THanks for the encouragement.
Old 08-12-07
Man, saab people are the best!
oliversexpedition (local saab collector) is loaning me some tools for the weekend!
Just gotta keep my fingers crossed that theres a 900 at the yard!
Old 08-12-07
DanF.'s Avatar
DanF. DanF. is offline
My Saabs: 1997 9000 Aero 5-speed
Good luck buddy. If I were closer I'd lend some tools and a hand. Hell, I'd bring the beer too. Lots of beer.
Dan
*SAABCentral NEW ENGLAND CREW Member 008* (now in NC)
T5Suite2.0 Stage 3+, Full DIY 3" exhaust w/Magnaflow, Spec stage 2+ clutch, "Custom" airbox mod, Forge BPV, DIY strut brace, Poly bushings, various powder-coated goodies
Old 08-12-07
woywitka's Avatar
woywitka woywitka is offline
My Saabs: '87 900 T16 vert, 911 SC,914,W123 Diesel
even if you can't get one out of the yard they are $50 on eeuroparts.com I believe.
That really sucks man, we had a siilar snow here and one of the members in our Saab club came up from Washington for the meet and did a similar thing.
It happens to the best of us.
Fun times:
Classic Saab 900 Turbo Convertible, Porsche 911
Old 08-12-07
Mag-X's Avatar
Mag-X Mag-X is offline
My Saabs: 2010 Saab 9-3 2.0T
Man that sucks.
I cannot imagine what it's going to be like when it snows here. My parking lot at home is on one big, steep hill.
sudo chown -R us ./base
Old 08-12-07
woywitka's Avatar
Originally Posted by Mag-X
Man that sucks.
How often do does the snow reach Portland? Less than Seattle I would think?
Fun times:
Old 08-12-07
IronJoe's Avatar
IronJoe IronJoe is offline
My Saabs: '87 Airflow Convertible, '08 Turbo X SC
Garage
Ugh, sorry to hear that RB.
Time to get some nordfrosts on your old 15" sunbursts!
*1988 BMW M3* - Current project
*1987 Airflow vert project thread* - 400bhp, Eurotuner Magazine Feature Car - Now on T5
*1987 SPG project thread* - Sold
*1999 Lightning Blue 9³ Viggen* - Sold
Old 08-12-07
DanF.'s Avatar
for winter, the old steel wheels do pretty good. I konw I don't car how bad they get banged up.
Old 08-12-07
900t's Avatar
900t 900t is offline
Saabista
Sounds like you did exactly what mikewiththespike did last year
Old 08-12-07
Thanks for the kind words, guys! Well, I'm back. I found a 900t vert with one, it was a little rusty, and I got it 90% off, but I couldn't find the 19mm long socket that I had borrowed in my bucket, and then I got kicked out (they closed). Of course when I got back to my car, I found the dang socket in the most obvious of spots So I'm gonna get up at the butt crack of dawn tommorow and be there with the one tool i need right when they open and spend 4 minutes taking the rest of the thing off. Then rush back, put it on, all in time to watch the Bills shellack the Dolphins at 1:00!!!
Except I was going probably 5 mph and not trying to impress anyone! Seriously, the ice made me accelerate down the hill into the curb, despite my best efforts
The heartbreaker here, though, are the two dings in my superaero. I hope I can find someone who can fix it, or at least find another one for sale.
Old 08-12-07
DanF.'s Avatar
Originally Posted by TheRedBaron
Except I was going probably 5 mph and not trying to impress anyone! Seriously, the planet's gravity made me accelerate down the hill into the curb, despite my best efforts
That makes more sense.
Old 08-12-07
Well, to compromise, let's say "the planet's gravity combined with the ice"
Old 08-12-07
IronJoe's Avatar
Garage
I wish you'd stop showing off in your car all the time.
Old 08-12-07
Ok fine, there were three high school girls on the corner. I yelled out the window "Hey, ladies, you know who erik carlsson is?!?!" tried to left foot brake around the corner at high speed, and proceeded to sh*t the bed into the curb.
I can still hear them laughing.
Old 09-12-07
deniss's Avatar
deniss deniss is offline
My Saabs: '08 9-3 Combi 2.0T 6-sp
where do you support your car with the jack-stands when you replace the lower control arm? whenever i have the car up on the jacks, i always anchor them against one of the lower control arm mounts... for a lower control arm repair, i cant imagine where i'd put the jack stands...
Old 09-12-07
TooMany2cvs's Avatar
TooMany2cvs TooMany2cvs is offline
Saabista
My Saabs: '90 900T16 3dr - For Sale!
Quite. EVERYbody knows that if you're going to imitate Erik, you have to roll the damn thing. He didn't get known as Erik-on-the-roof for nothing.
Honestly. Amateurs.
Adrian
Soon to be living life on the road in an old VW
http://WhereverTheRoadGoes.com
Old 09-12-07
Deniss, the car at the junkyard was just supported by tires, but when I do my car I will just use factory mounting points on the side of the car with maybe a backup stand up front.
Honestly. Amateurs.
Hahahahahahaha you're too much!
Old 09-12-07
SteveTheFolkie's Avatar
SteveTheFolkie SteveTheFolkie is offline
My Saabs: 1987 900 8V
so I'm not the only one known for "grace under pressure" eh?
Sorry to hear of your mis-adventure RB - hope you got it all sorted out - I feel like a real sh1t for not reading this earlier and coming down to help you out -
Have a great holiday
steve
