The little Cabin Hot or Cold temp Knob busted! - SaabCentral Forums
Old 06-12-07
WaSaabiPSI's Avatar
WaSaabiPSI WaSaabiPSI is offline
Banned
My Saabs: '99 9-3 3.5'' FMIC and Forge Wastegate
Default The little Cabin Hot or Cold temp Knob busted!
So, it just got pretty cold outside, I havent driven my Saab in a very long while so the temp was set all the way to "cool". When I hastily went to turn the fricking heat on, the knob broke. So basically, anyone know where to get one and I'm more interested what Saab is going to charge me for this. I'm guessing since its poorly manufactured and GM now owns them, ummm let me see..... $30????
seriously though, anyone know?
Old 06-12-07
Pete67 Pete67 is offline
My Saabs: 900 V6
You don't need to pay dealer prices, have a look on ebay you should pick up either the knob itself or the white plastic shaft behind it for a few bucks...
Old 06-12-07
GaryG GaryG is offline
My Saabs: Curently: 06 9-5 Aero & 02 9-3 SE
As a preventative measure, I put a little metal clamp around the white plastic knob where it connects to the shaft. This supports the plastic and prevents it from splitting. Those little compression clamps that come with fuel line filters work great but you have to trim off a little on one of the tabs so it doesn't catch when the knob turns.
If your internal vent control is stiff you'll still need to lube it as well.
Old 06-12-07
WaSaabiPSI's Avatar
Banned
Nice! thats such a good idea, thanks man!
Old 06-12-07
WaSaabiPSI's Avatar
Banned
how do i lubve the internal shaft? haha
Old 06-12-07
bntroberts's Avatar
bntroberts bntroberts is offline
My Saabs: 2001 Saab 9³ no more :'(
You can buy these for 10 bucks from eeuroparts...I have a broken one that I've been meaning to fix for a while...it's still good enough to turn though, but needs to be replaced.
Old 08-12-07
forcebomr forcebomr is offline
My Saabs: 1995 Saab 900S
I had the same problem, my vent location knob broke and then one night while trying desparately to turn on the defroster for the windshield I thought I'd be clever and use the unbroken knob on the vent location place and broke that too... What I ended up doing was putting a small metal spring around the little plastic pice and loads of epoxy on it. They seem to still be okay.
Old 10-12-07
First remove the side kick panels of the console to gain access to the heating / ventilation parts. The left knob operates a cable. Trace it to the opposite end where it operates the control valve and spray the ends with some light lube. It should move freely.
The right knob rotates the "toilet paper roll" which connects to the air handler unit. I sprayed some light lube into the air handler connection and moved it a bit. The console knob now has much less resistance.
