Non standard toe for modded suspension? - SaabCentral Forums
Old 04-12-07
Shirozina Shirozina is offline
My Saabs: 2002 9-3 aero 5spd 3dr
Default Non standard toe for modded suspension?
Stock toe settings are designed to work with the compliance in the stock bushings - toe will vary on acceleration and deceleration much more and the thus the dynamic setting will be different. Anyone here who is running with polybushings ever had their toe adjusted differently to the stock setting and how did it change the feel of the car. I'm still getting this slightly vague and unstable feeling when driving on the M-way and have heard that these cars are super sensitive to the toe setting. My current setting is 0deg and 13mins total toe in but this was done on my old 18"' 'drug-dealer' wheels. I'm tempted to go nearer to O deg.
2002 9-3 Aero 3dr 5spd
Old 04-12-07
hunt.dogshome's Avatar
hunt.dogshome hunt.dogshome is offline
My Saabs: Clanky 9-3 diesel.
You know how I do mine
Gone out 1/2 flat to got her how I like it with the revised ride height.
But yes, the amount of play in your bushes will 'set' the dynamic toe at cruising speed. So in theory, less toe for stiffer bushes as the wheels don't get pushed back so far.
Perhaps the 'try it and see' method of adjustment is not technical enough
肉(rņu)包(bāo)子(zi)打(dǎ)狗(gǒu) (meat+bun(2nd and 3rd)+hit+dog)
* Literally: To hit a dog with a meat-bun.:-O
Old 04-12-07
mfyoung mfyoung is offline
My Saabs: 1998 saab 900se, 1983 900s
i prefer a couple degrees of toe out
trying to get oversteer in fwd cars sucks
http://img306.imageshack.us/img306/9...crappy1gr0.jpg
1998 Saab 900 SE, 3"DP, 3" catback, FMIC
Old 05-12-07
A couple of degree's - are you sure you don't mean mins? - Can you drive it in a straight line like this without having to constantly correct the steering? Why do you want oversteer?
Old 05-12-07
Corn Cob Corn Cob is offline
My Saabs: 1998 900 SE, 1990 Volvo 240 wagon
Because he thinks he's Stig Blomqvist.
If evolution is outlawed, only outlaws will evolve.
Old 05-12-07
mike saunders's Avatar
mike saunders mike saunders is offline
Saabista
My Saabs: N/A
Widen the front track with 20mm spacers, set front toe in at -2, add stiffer rear ARB....
Slight understeer when pushed.......
Old 05-12-07
I'm after straightline stability at the moment - most of my driving is on the M-way. It's pretty neutral when pushed hard into country road corners (koni's full soft and 38psi all round) but I can induce over or understeer with slight adjustment to tyre pressures or shock settings.
Old 05-12-07
G96nt's Avatar
G96nt G96nt is offline
My Saabs: 99 9-3: sold. 95 SEt: sold. '00 GF
You guys ever sit back, look @ what you type, and think you take things a little TOO seriously?
What are you doing on the M-way that "straight line stability" really matters?
Craig R.
2kGF!
Eibach, B&G, EBC, JT, Hawk, ARP.
Old 05-12-07
I'm trying to drive comfortably in a straight line without having to feed in steering corrections everytime I go over a slight indulation in the road or get hit by a bit of sidewind - this is a normal expectation from a car - straightline stability.
Old 05-12-07
G96nt's Avatar
So, set toe to zero, camber to zero and run high-profile tires @ 30psi
problem solved.
All the straight-line stability you could ever need!
Really... you can't have both.
You'll have a car that turns well, or goes straight well...or a compromise in one for the other.
Craig R.
2kGF!
Old 05-12-07
-2? Sounds reasonable. Check!
Stiffer rear ARB? Check!
Don't understand spacer part though
G86NT: Straight line stability very useful for the normal run to work and back also. A twitchy, wandering thing isn't good for that
Old 05-12-07
problem solved.
Zero toe will lead to instability and a loose feel as the small amount of play in all the suspension and steering joints will cause the wheels to wander about. Negative or positive toe takes up the slack by putting the joints under compression or tension. Toe in creates straight line stability at the expense of turn in but too much wears the tyres. Toe out makes for fast turn in but instability in a straight line. I know what these things do - I just want someone to tell me what they have set their toe to with poly bushes.
Old 05-12-07
lol, no i think i'm per eklund
and yes i set a degree of toe out for auto-x course's, and rally-x course's where speeds rarely exceed 40 or 50, and never for more than a couple of seconds
Old 06-12-07
Tweek's Turbos Tweek's Turbos is offline
My Saabs: 07 9-5 Combi, 99 9-3 Viggen, 85 900 SPG
So do we have a difinitive setting? I know Abbott has the rear setting up on the website. But what do we want for the front for var. applications?
Old 06-12-07
It would be nice to know what people think for both strait line and cornering, the shop I work in does alignments and I could probally get a free one.
