Instructions for replacing turbo? - SaabCentral Forums
Go Back   SaabCentral Forums > Saab 9-3 SportSedan/Convertible ('04+)/Combi, 2003-2011 > Saab 9-3 SS, Combi & Convertible Performance, Mods & Tuning
Saab 9-3 SS, Combi & Convertible Performance, Mods & Tuning Covers Tuning & Performance modifications for the Saab 9-3 Sports Saloon/Sedan, Combi & Convertible
Old 01-12-07
Frosty288's Avatar
Frosty288 Frosty288 is offline
My Saabs: 2009 9-3 2.0T
Default Instructions for replacing turbo?
I'm told it's an easy bolt on procedure, but i'd like to get a set of instructions. The reason is I didn't expect the ECU to be so easy, and since I can replace the ECU myself, it would save me a ton of money if I could do the turbo and downpipe as well.
Old 01-12-07
mike saunders's Avatar
mike saunders mike saunders is offline
Saabista
My Saabs: N/A
1: Disconnect turbo bits
2: ???
3: Replace!
Seriously though, the procedure is probably much like it is with any cars with modern oil and water cooled turbos, but you lucky sods have the turbo placed in an easily accessible place, basically on top of the blinkin' engine.
I've only poked around an SS a couple of times, but I think your coolant and oil lines are able to be removed from the turbo itself, so you don;t have to screw around with removing the manifold as a unit with turbo and the lines (which is sometimes the easiest way to deal with the 94-02 models)
Old 01-12-07
Frosty288's Avatar
Will the BSR downpipe fit on the new TD04-16T turbo? I'd assume it would, since it's really just a different compressor, unless i'm wrong.
Old 01-12-07
VectorDan's Avatar
VectorDan VectorDan is offline
My Saabs: 2003 9-3SS 2.0t Vector BSR Stage 3
The BSR dp for the 175hp and the 210hp have the same part number, so yes.
Svenska Aeroplan Aktiebolaget
Old 03-12-07
michaLcoughliN michaLcoughliN is offline
Banned
My Saabs: 03' Saab 9-3SS linear
a turbo is quite easy an as simple as it sounds. It mounts onto the exhaust manifold by 4 bolts. simple remove the nuts, remove the oil feed and oil return lines and thats it. It should come right out.
When replacing, put on new turbo, use new gaskets for oil feed and return lines. Tighten up nuts . And then proceed by changing the oil.
I recommend always changing the oil. And if you have the time / tools / etc
Ide personally would drop the oil pan to see if the sump is clogged, and get a good cleaning of the debree in the bottom of the pan (if any)
