I've put a 1985 gearbox into my 1988 T16. I take it the '85 gearbox had the centering mechanism in the linkages rather than the box. so i need the appropriate linkages?
or is there a way to use the newer type linkages with old box? Cheers!
Current jobs : 16" super aeros restoration 1980 Black 99T 2 door restoration |
| Sponsored Links | ||
Advertisement | ||
The centering mechanism is bolted to the front of the gear selector housing and has a cam piece on the selector shaft too. I don't know if the later housings have the bolt holes but I'd say the shaft has no cam. Best bet would be to go looking for the housing and shaft...
The shaft definately doesnt have the cam on it if it didnt come off a car with the centering mechanism.
The centering bit screws into the plastic base section through 2 holes in the front. I think even the 4 speed plastic base i took off my 99 had the 2 holes in the front where the centering mechanism would attach. If the 5 spd gearbox i have on my 99 is the proper one for the car it came off (which had the centering mechanism which i didnt fit to the 99) then there is no problem atall using it without the centering bits. It is fine to drive. |
You can use an earlier linkage on a later box but not the other way around, well you'll be fishing for gears more.
this is the difference
Psytuned 1997 900 Sensonic coupe turbo |
Craig.
Craig Dewick - Wollombi/Laguna, NSW, .au- Websites Flickr - 23 - Saab C900's - Saab 99's - Saab 9000's - Free non-commercial Classic Saab albums and Classic Saab forums - RIP Moose.Parts which these forums still ILLEGALLY censor any mention of in postings! |
Lower one is the early one with the centering mechanism bolted to the lever assembly (its basically a big cam on the rod and some springs and runners round it so it centers the lever). Quote:
The only time you really notice it is going down from 5th into 3rd or 4th - where it would auto center it doesnt quite do it - but after a couple of days you know where it is anyhow and you can feel where it should be! |
| Sponsored Links | |
Advertisement | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
