9000 won't start - SaabCentral Forums
Go Back   SaabCentral Forums > Saab 9000 > Saab 9000 Workshop
Saab 9000 Workshop Saab 9000 (1985-1998) Technical Forum
Old 28-10-07
Phil9000 Phil9000 is offline
My Saabs: 9000 CSE 2.3 ecopower
Default 9000 won't start
I have a 97 2.3 LPT 9000
It has been running fine and now suddenly just won't start. There's plenty of battery power. It's just as though the immobiliser was on - but I have used the key fob alarm to disbale this.
I'm at a loss.
Anyone got ideas?
Old 28-10-07
Just had the idea to swap the ignition cartidge with another I happened to have available. Hey presto! Started first time.
is it normal for a DI catrtridge to just completely fail like this?
Old 28-10-07
tristan_the_trout's Avatar
tristan_the_trout tristan_the_trout is offline
My Saabs: 1991 9000 2.3T Imola Red
not really.. From what i hear.. and by design... usually they start misfiring a lot first... kinda rare for them to die period... much less that spontaneously.. strannnge
-=tristan=-
'91 900 - R.I.P.
'91 9000 2.3L Turbo "Phoenix" - R.I.P. You will be missed
'95 900SE 2.0t Convertible - Flooded during Irene
'91 9000 2.3 Turbo Imola Red
Old 29-10-07
richardthebrit richardthebrit is offline
My Saabs: 9000 CSE manual, Hirch ECU & Aero kit
I've had the same experience on a 2 litre 900 HPT. No sign of a problem until I parked the car up one morning and then tried to restart it a couple hours later....nothing. The giveaway is a strong smell of electrical insulation buring when you lift the bonnet.
The RAC carry spare SAAB DI packs in most areas because it's a common failure mode, but rarely have both the red & the black available.
If the problem is not common in the US then different suppliers may hold the answer.
Old 29-10-07
Jssaab Jssaab is offline
My Saabs: 2000 9-5 320hp, 2003 Aero Hirsch "Clone"
Did you check the CPS ( Crank Positon Sensor) Mine went out this week, replaced it Sat. Had no spark, died while hot. ( Would not respart after shutting it down) Runs fine now.
I have the 9-5 but the 2.3 block all had them I think...
J
