The First post, every new turbo-owner should read! - SaabCentral Forums
Go Back   SaabCentral Forums > Saab C900, 1979-1993 & '94 Convertible (C=classic) > C900 Performance, Mods & Tuning
C900 Performance, Mods & Tuning Covers Tuning & Performance modifications for the Classic 900 (C900)
Old 26th October 2007
Saab-Daniel's Avatar
Saab-Daniel Saab-Daniel is offline
My Saabs: '91 Monte Carlo 'vert
Default The First post, every new turbo-owner should read!
Wuhuu, you've got a turbo! First now, what do you do!?
You:
1. Change the oil to full synthetic quality oil and filter, regardless of what the PO says.
2. You change the coolant and flush the system, regardless of what the PO says.
3. You replace all ignition components, that being the rotor, cap, leads and plugs (NGK BCP7EVX for 16v turbo, BP7ES for 8v turbo), regardless of what the PO says.
4. You investigate or/and replace all vacuum-hoses, regardless of what the PO says.
5. You test/replace the bypass-valve, regardless of what the PO says.
6. You unplug the connector on top of the APC-solenoid (located above the radiator, with three large vacuum-hoses going out of it, and a connector on top), to check the base-boost. Drive the car warm, find an inclining road, go into third and floor it. Note the boost on the CALIBRATED boost-gauge, and adjust to 6 psi or 0.45 bar. Shorten the actuator rod for higher boost, lengthen it for lower boost.
Yipeee, NOW you're ready to start modding...
THEN! The first you do is:
1. Mod the APC as per www.900aero.com, realise it isn't enough, and
2. Mod as per http://www.saabcentral.com/forums/sh...ghlight=newest
3. Change broken gearbox
4.. Fit fuel-chip, that dosn't quite cut it, as you run lean at some points, and rich at others.
4. Do the vacuum-capsule mod http://www.saabcentral.com/forums/sh...ht=walkthrough
5. Change to new gearbox
6. Realise you need a bigger turbo, find and fit...
7. Realise you don't have the correct fuelling and ignition-control...
8. Search the project-threads, and find out Megasquirt is your next step towards insane power....
9. Fit strengthened gearbox
10. Join the Dark side with the rest of us!
Regards,
The Reverend...
Still preaching MS...!
They call him... "The Reverend"....
Now with C900 Monte Carlo Convertible, weekend-cruiser :-)
IronJoe's Avatar
IronJoe IronJoe is offline
My Saabs: '87 Airflow Convertible, '08 Turbo X SC
Garage
sticky.
speedparts
- Current project
- 400bhp, Eurotuner Magazine Feature Car -
- Sold
- Sold
grif900's Avatar
grif900 grif900 is offline
My Saabs: 1988 900 SPG
Originally Posted by IronJoe
sticky.
I second that. Luke, Feel the power of the dark side.
TheRedBaron's Avatar
TheRedBaron TheRedBaron is offline
My Saabs: 1990 900 turbo
lol - fantastic, although Jim will you for replacing components that don't need replacing
Daniel in the 2nd part you forgot step 2.5 - chuckle to yourself after you show that V8 mustang what a saab can do and then 2.6 - you realize that that STI or EVO you saw on the highway the other day isn't that fast
The faster you go, the more you see.
Old 11th November 2007
Williamalwyn Williamalwyn is offline
New Member
My Saabs: 94 900 Turbo convertible
Thumbs up Numero Uno Post
For my first Post I would like to say, All this information is certainly some good advice. The only item I tend to disagree with is the synthetic oil, but that is ONLY because I have only used regular oil so I really can't judge the True difference. My 94 Saab turbo has run Dino since day One but I may givee the synthetic oil a try
Old 12th November 2007
misu's Avatar
misu misu is offline
My Saabs: 900 conv. T16V, '91, 9-5 3.0V6 auto, '99
Darth Vader personally...
Sorry, but I really "feel" him from this picture...
Old 14th November 2007
New Member
COOL CAR FOR SURE S W E E T
Old 23rd January 2008
REYNOLDS REYNOLDS is offline
Hey Daniel This is my first post after reading the first post every new owner should read. Do you still reccomend full syn. eeven on a 200,000 mile plus turbo car ? In any case what weight oil would you advise me to use wether synthetic or not?? Thanks
grif900's Avatar
I can't speak for dan, but I would recomend 10-30 dyno-oil.
Old 24th January 2008
Thanks Grif,
Don't really know much about the history of the car so I just would like to do it right while she's in my hands.
Old 25th January 2008
I use different high quality fully synthetic oils, castrol, mobil1 etc. 10/40, 5/40, 10/50, 5/50, didn't notice much difference, I must say, between them...
Daniel.
Old 8th March 2008
nigelgrn's Avatar
nigelgrn nigelgrn is offline
My Saabs: 1988 SAAB 900 TURBO AERO
Hey Daniel thats a great resource, I love it when someone does a great summary like that and I'm sure that it helps a lot for anyone contemplating a restoration of one of these great cars.
One question I have for you is what do you do to strengthen the 5-speed pre 1990 box to allow higher hp mods to atleast have a chance of not ruining the box?
Eurolux NZ
Old 22nd March 2008
Donkehote Donkehote is offline
My Saabs: 1993 900S (RIP 1990 spg)
I have looked arround a little bit ( but probabally not enuf :P) and i cant seem to find any information on where anyone got theyre megasquirt kit from.
Can someone post a link?
Thanks
Old 22nd March 2008
www.diyautotune.com is my pusher, the best on the netz...
Others are available too, though, but the above is one of the most trusted US-based. in Europe, www.extra-efi.co.uk is also a possibility.
Daniel.
Old 27th March 2008
noturbo noturbo is offline
New Member
My Saabs: swedish
Non-synthetic oil is as useful as a VHS tape
:-P
Old 30th April 2008
makai72iraq makai72iraq is offline
My Saabs: 94 900, 06 9-5 "sport/aero"
Default Royal Purple
How about Royal Purple synth. Have used this on my old 240 volvo 85 non turbo along with mobil 1 oil filter and was taking down 5.0 mustangs on a little hill numerous times. Then I added it to my 87 900 and it seemed to respond a little better.
Old 30th April 2008
grif900's Avatar
Ihmo, good oil with purple dye added to it will not make your car go faster or last any longer,please don't start another oil-thread (the subject has been beaten to death 'round here. Search,read ,learn).
I've left many 5.nothing drivers in the dust but, I am quite shure that I (me, and my 20 year old Saab) lulled them into a false sence of security and then took them by suprise.
p.s. I failed to mention good driving skills on my part.
Old 24th July 2008
machinehead machinehead is offline
New Member
My Saabs: 900 turbo convertable
hey i was just wanting to know how much boost can a factory saab 900 2.0 engine take
Old 24th July 2008
unkleG'sif's Avatar
unkleG'sif unkleG'sif is offline
My Saabs: 1993 T16 (xLPT) - 1994 RUBY!!!
none, without a decent amount of work......
i forward you to a famous image, created by one of our own
G
"we can allow satellites, planets, suns, universe, nay whole systems of universe[s,] to be governed by laws, but the smallest insect, we wish to be created at once by special act" - Charles Darwin
Old 26th July 2008
New Member
Thumbs up
This is a MOST Excellent Post! Some Words to LIVE BY
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
