rough idle cold - SaabCentral Forums
Go Back   SaabCentral Forums > Saab 9000 > 9000 Workshop
9000 Workshop 9000 (1985-1998) Technical Forum
Old 25th October 2007
saabfan9's Avatar
saabfan9 saabfan9 is offline
My Saabs: 1973 99 EMS..2003 9-5 AERO..1984 900s..
Default rough idle cold
hey guys my 96 aero at start up has a very rough idle after a minute she'll smooth out...no engine light and after seems to run just fine..any ideas? thanks for any help..chris
eerstkoffie eerstkoffie is offline
My Saabs: 9000 CS 2.3 Automatic '92
i've had similar problems.
had a small leak in the plastic piece connected to the hose that is right out of the fuel tank.
changed my fuel filter. needs to be done after 150.000 k.
changed temp sensor on engine, its between the second and third fuel injector.
changed sparks for the proper NGK's.
DI module could be bad. they're on e-bay.
saabfan9's Avatar
thank you eerst i will start doing a check on these things...did you get the problem dailed in? thanks for the input
my swedish girlie runs well now, although cold idle is not perfect yet. but stable. guess they call that character, or charme ;-)
the temperature sensor between the injectors gave the most improvement.
thanks to someone here on the forum, i found it.
if the sensor is not connected, or broken, the engine gets the signal that it is warm all the time. so it wont start. but the sensor has like three steps, or measurements : warm / in betweem / cold. so it could cause your prob too.
Old 27th October 2007
saabfan9's Avatar
what are some early signs of the di failing? i've owned several saabs but lucky enough not to have one fail...
mine didn't fail till now. but i know from the cars history that it has been changed once. theu seem to last for around a 150.000 km.
i've heard you can notice it, cause it starts difficult, runs on 3 cilinders or rough.
maybe some more experienced forum readers could give this a more accurate follow up ?
SaabKen's Avatar
SaabKen SaabKen is offline
My Saabs: '06 9 2.0T Combi, BCB Stg 2
Garage
When mine was wonky, I'd always get the CEL (forget how many flashes). Indie just ripped out the old and plugged in a new one. Ta-da !
I find the fuel octane affects morning 1st cold start idle. With 87 I'd always get some minor stuttering stuttering stuttering (but never dies or anything), but with 89 or higher the smoothness will definitely be there with no roughness.
2006 9 2.0T SportCombi BCB Stg 2 | 2004 Subaru Outback H6 3.0 | 1993 9000 CSE (RIP)
"Honesty is the best policy, but insanity is a better defense." - Steve Landesberg
hmmm.... in this country, you can't get any less than octane 95.
but mine is still a lttle rough on cold idle.
it starts right a way, but, once it fires, i have to push the pedal just a little, otherwise it will stop. after like 10 secs running, i can leave the pedal alone. and she runs perfect from then.
character ? ;-)
saabfan9's Avatar
she starts right up (no long crank)..but you can barely make it down the block very crabby and embarassing.. i would say aprox. 2-3 minutes she'll smooth out and not be a problem for the rest of the trip..no check engine light..never dies out just runs like **** ..idle control valve would give a die out at stops...thanks everyone for the help
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
