Do I have to divorce the SID? (9-3 S / 2000) - SaabCentral Forums
Old 21st October 2007
rk93 rk93 is offline
My Saabs: 2007 9-3 Aero Convertible 2000 Saab 9-3
Default Do I have to divorce the SID? (9-3 S / 2000)
I understand that that radio needs to be properly 'divorced' when unplugging so that it can be properly re-installed.
Is this also the case with the SID?
And, if so, how is this accomplished.
I appreciate anyone's help.
Thanks,
rk93
jstanist jstanist is offline
My Saabs: 2000 9-3 SE 5 door
Smile
HI RK,
I've also got a '00 9-3 SE and I've taken the SID out a few times to fix the display and have not done anything other than remove and unplug then replug and replace.
Joe
Edison517's Avatar
Edison517 Edison517 is offline
My Saabs: 2000 Black 5 door Viggen
actually, it's my understanding that the radio being divorced and married only applies when you move it to another vehicle. I bought a used radio from goldwing, which they had divorced properly, and I plugged it into my car and had the dealership marry it to my car. you can remove and install from the same car all day and not need to worry about divorcing/marrying because the car knows it's the same radio.
the SID I believe does not get divorced/married...but I could be wrong...
the AC panel does not get divorced/married at all; I bought a used one of those from the same place, and it was straight plug and play. no need to visit the stealership for the TechII procedure.
Seth
'00 Viggen, 79k
Old 22nd October 2007
Drew'sSaab Drew'sSaab is offline
My Saabs: 1997 Saab 900SE Turbo
there is alot of marrying and divorcing in the saab world......lol lol lol lol lol lol
hkayssi hkayssi is offline
My Saabs: 1997 900S
Seth
'00 Viggen, 79k
Not necessarily true all the time. In some cases you need to program it to the car in order to have some of the functions work properly. For a new or remanufactures SID you need to program it with the Tech II.
Chris 9-5's Avatar
Saab Sage!
My Saabs: .
rk93
The radio only has to be divorced for it to be fitted to a different vehicle - and it will then need marrying to that new vehicle - this is done using Tech 2 Saab's diagnostic / programming tool. (you do not need to do this if you are putting it back into the same car)
The marrying bit is to do with security and the vin number is required this stops people stealing your radio as it wont work in another car
The SID does not need to be married or divorced however some functions do need programming, again via TEch 2 as has been stated. (Again you do NOT need to do this if refitting to the same car.)
fromero's Avatar
fromero fromero is offline
My Saabs: '02-93 Conv. 310Hp/435Nm
Maybe not the same question but sa you guys seem very knowledgeable..
I am selling my ECU from my previuos tune, do I need to divorce or anything before taking it out of my car so it can be fitted in another 93?
I know in the new car it has to be programmed regarding the immobiliser...
Thanks
'02-93-2.0T Conv. Maptun Stage 5. '06-95Aero intake. 3" Stainless steel downpipe & race cat. Bilstein/Eibach. ETS Intercooler-Forge Dumpvalve. 22mm ARB. Six point subframe brace. Viggen 308mm front brakes & 95Aero 300mm rear brakes. Full suspension kit, Strut bar & Steering Clamp & brace by GenuineSaab..Lots_O_Fun
Chris 9-5's Avatar
Saab Sage!
My Saabs: .
Nope
Default Thanks All
No divorcing / No re-marriage.
And with a new SID... I feel like I have a new car...
Thanks,
rk93
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
