HELP! clutch input shaft seal - SaabCentral Forums
Old 20-10-07
aznsaab aznsaab is offline
My Saabs: 91 C900 5spd N/A
Exclamation HELP! clutch input shaft seal
sorry for the urgent plead, Trying to get her running today. I am attempting to get the input shaft seal out. I got the inside part (well tore it out) but the outside part seems pretty siezed to the trans housing. Any tips or trick to get it out? I'll prolly need some tips as to the best way to get it back in as well.
Thanks
Old 20-10-07
Squaab99t's Avatar
Squaab99t Squaab99t is offline
My Saabs: '89 900t 4dr '78 99t 3dr '76 99ems 16vt
It should come out with a flat blade screw driver or small prybar. Lightly tap the new one in with not beat up face hammer. Striking the outer diameter work back and forth so it goes in evenly.
Old 20-10-07
grif900's Avatar
grif900 grif900 is offline
My Saabs: 1988 900 SPG
Another method for a stuck seal is to drill a few small holes in it (make shure to catch the swarf, not too hard to do) and put small self tapping screws in the holes, then pry the screw heads.
Old 20-10-07
dougsaab's Avatar
dougsaab dougsaab is offline
My Saabs: '73 99EMS, 86 900T, 88 900T vert
Heat it with a propane torch and it should pop right out.
