| Saab 9-5 Performance, Mods & Tuning Covers Tuning & Performance modifications for the Saab 9-5 |
Well I finally found some time to install my new suspension, but considering how much of a PITA it is to get the top nut off the front struts it took me like 8 hours to finish the front and I ran out of time and will tackle the rear tomorrow. I took the car for a quick test drive around the block and am a little worried to say the least.
I'm noticing that ~10-15MPH turns around corners, I'm hearing a not very pleasant thumping / popping tension related knock and can feel the vibrations inside the car. I only took a few turns and it seems to be getting better, however it's a very unnerving. The car feels solid in a straight line but any time i turn the wheel, this noise/vibration occurs and scares the crap outta me. I installed everything in reverse order of taking it apart, noticing all the correct torque specs. Is this normal for a new suspension install? Are the springs just settling, or do I have a more serious problem at hand? I know i need an alignment, but i dont know how that could affect the sounds i'm hearing. Any suggestions would be great.. Thanks! and for your viewing pleasure...... ![]()
| Sponsored Links | ||
Advertisement | ||
There will be some settling in to be done.
Mine takes a little while even just after being jacked up
I decline to grant to SAABCENTRAL.COM a non exclusive, royalty free, worldwide, perpetual license to reproduce, distribute, transmit, sublicense, create derivative works of, publicly display, publish and perform any materials and other information I submit to any public areas.... |
Thank You for the reassurance, I might have been just over reacting. After another laid back drive, There's significantly less noise but still a bit. It's such a violent sound though, it makes me nervous every time.
I also have a question about the stock bump stops. I took a look at Koni's FAQ, and they suggest reusing the stock stops. I dropped them on the piston(They dont' hug the koni's like they do w/ stock) and put everything back together. Now that I think about it though, since the spring drops the ride hight ~1.25" should I have compensated that amount and cut the bump stops. I'm now worried about rolling over speed bumps and such.. -Dave |
| Sponsored Links | |
Advertisement | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
