It isn't as bad as it looks. Please, tell me it isn't as bad as it looks. PLEASE?
Did I mention I hate water cooled cars? I've *never* had one that hasn't given me the odd bit of grief with the cooling system. NEVER. (Oh, and is there REALLY that big a difference between OEM and "aftermarket" pumps? SIX times the price?)
Adrian Soon to be living life on the road in an old VW http://WhereverTheRoadGoes.com |
| Sponsored Links | ||
Advertisement | ||
Nothing to it.
Don't remove the A/C compressor, just the A/C belt. Take the pulley off the pump first, and with it, the belts will come loose. 5 or 6 bolts, then pry the pump loose, let the coolant drain into the pre-positioned drain pan. Prop a mirror on the brake line that runs along the firewall. Scrape the gasket (this is the most time-consuming part). Assembly is the reverse. Start 1 bolt on the water pump pulley, slip the belts on, then force the pulley back into place (it will be obvious when you do it). Refill, bleed if you like. I worked with a guy who could do them (with air tools) in 17 minutes; it always took me 30 minutes. He did 4 a week. They didn't give me too many because I was so slow.
Corporations are people! If you prick them, do they not bleed? If you tickle them, do they not laugh? If you poison them, do they not die? |
So - it's gone through about 750ml in roughly two-three weeks. I'm unlikely to be able to do it this week, and got about 300 miles to do over the weekend. Likelihood of it suddenly exploding and dumping the lot?
MMmmmmmm. Juicy Fruit. |
Isn't it there another Saab owner near you who could help?
And, since it's used about a litre since yesterday evening, for 30 miles or so... I can get a pump from GSF by tomorrow morning, straight to my mate's workshop, so that's what's happening. Did I mention that I hate water-cooled cars? Did I? <mutters> Mebbe I should have gone absolutely barking mad and bought a Tatra instead...
You wuss!
Dont ever buy an older saab - you need a special tool to pull out and refit the old style B engine pump! Yours is really easy! |
Yup, that's me. Quote:
It was the fact you can barely see the damn thing that was scaring me... I'm used to Citroens, where even if you CAN see it, it'll be a bugger to get to - having something that's barely visible but easy to do is doing my fruit in.
why don't you get one when you get to fakenham??
22saabs |
Was it a noob intelligence test (which I failed miserably...)? A weeny matter of "Don't look at the aircon compressor, decide it looks awkward to remove and won't help much anyway, so leave it - TAKE THE AIRCON COMPRESSOR OFF..."? First mistake was looking up from under the car, thinking the bottom crank pulley was the waterpump, and removing the three small bolts for the aircon pulley... (Belt long since AWOL, but I want to get it working again at some point) OK, I could now see the water pump pulley. Got that off, all the five bolts off, and the pump off. Damn. It's newish ('01 datestamp on the casting), feels good and tight, and is *spotless*. Oh. Bugger. Wonder where the water IS coming from... With a torch and a mirror, can't see anything, but the top of the crank pulley is covered in coolant stains. Humph about a bit, then decide that I'm going to have to bite the bullet and get the damn compressor and bracket out the way, together with the tensioner pulley. Not nearly as bad as I feared... Blimey, that waterpump IS easy to get at, isn't it...? Once the damn aircon compressor's out the way... No sign of anything leaking from anywhere else, so clean up the gasket face properly, new pump in, and it SEEMS to be watertight after about 300 miles over the weekend... <Fingers crossed>
I KNOW WHERE THE WATER'S GOING! (and how come the crank pulley was covered but the pump looked fine) The header tank's leaking! There's a pinhole just below the seam, slightly rear of the "tab". Just small enough so that if, hypothetically, you were to top the header up, take the car for a short but fast warm-up run, then whip the bonnet up to adjust the emissions... you can SEE a fine jet spraying straight onto the alternator...
Looking at the underside of the tank, there's a series of almost stress/aging cracks in the plastic, along the reverse curve round by the master cylinder. ![]() Click here for the clearer full-size image Looking at those pics, especially the fullsize, I suspect there'd been a loss from the end, too - see where the water's been running down? How odd. I think the pinhole leak was probably the first really visible symptom, and I suspect it would have failed properly at some stage in the not too distant future. Might be worth checking for any unexplained water losses.
I wish you had posted the symtoms first. The always 1/2 full and never lower coolant level would have been a dead giveaway, at least for me. Never the less, I'm glad you've got it sorted. So now you have a new tank and a new pump, you are now a radiator and a few hoses and clamps away from a very reliable liquid cooling system.
Firstly hello!!
You should be gratefull its not a motorbike, ive just had to take the carbs out of mine to get the thermostat back in!! and its still leaking.. Currently looking for a T16. have a Smart fortwo for sale. sorry for hijacking the thread Iain. |
"Hmmm. Not full. Was full. Fill" "Hmmm. Not full. Was full. Fill" "Hmmm. Not full. Was full. Fill" Quote:
Did I mention that I like aircooling?
No, you hadn't actually mentioned that.
| Sponsored Links | |
Advertisement | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
