Radio won't turn on - SaabCentral Forums
Old 30th September 2007
Aviator43 Aviator43 is offline
New Member
My Saabs: 900 SE convertible
Default Radio won't turn on
Hi,
I recently purchased a used 1996 Saab 900 SE convertible (if this is in the wrong section, please move it, as I couldn't seem to find a section for non-classic 900 models). Everything works great, except that the radio, and all its associated functions (tape, CD player etc) won't work. I have the radio code, the SID panel displays "CODE IN" when I turn on the car... but the radio itself makes no response when I press in "ON" button, and does nothing whatsoever when I enter the code.
The panel is backlit, but it's as if it's dead. What can I do to get the radio working? Thanks!
Old 1st October 2007
cdaly's Avatar
cdaly cdaly is offline
Moderator
My Saabs: '92 900LPT, '90 900i vert
What you need is the Saab 9-3 & NG900 Workshop. Moving now...
redrum's Avatar
redrum redrum is offline
My Saabs: 1997 900SE 2.0t
The 'Code-In' means that you need to enter the anti-theft code into the radio before it will work. It will ask for this any time the battery has been disconnected for more than a few minutes. There is a card that should have came with the owners manual that has this code on it (4 digits).
If you dont have that, you can probably get the code from a dealer if you give them your vin #. You might also try a generic number such as 1111 or the like, but its unlikely that this will work.
hkayssi hkayssi is offline
My Saabs: 1997 900S
I think the generic code is 1124 but it doesn't always work.
Try this
http://www.saabcentral.com/forums/sh...ght=radio+code
The search button can be much faster and more helpful sometimes
My Saabs: 1997 900S
Check this link for all other audio questions
http://www.saabcentral.com/forums/sh...69#post1065669
snoborderphx's Avatar
snoborderphx snoborderphx is offline
My Saabs: 94 Saab 900SE Turbo
Pull the radio out of the dash and check the connections in the back. If you are getting the "code-in" and you enter the code, it may be that the connections are not hooked on correctly.
Sno
My Saabs: 1997 900S
Or the 10 AMP fuse on the back of the radio is bad
Old 6th October 2007
New Member
Thanks for the replies! I removed the radio, and fidning all connections intact, I bought a new fuse and it worked! Thanks so much for the help
My Saabs: 1997 900S
Glad that helped
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
