Dash repair attempt II. Some of you might remember I recovered my dash with naugahyde a couple years back. That lasted pretty well, and would have probably still be going had I ever gotten around to stapling the edges and whatnot.
(in case any are wondering what a naugahyde is, see insert)>> ![]() First off I hit it with scary amounts of carb cleaner in an attempt to remove all the old glue. Nasty stuff. I hear very good things about 3M adhesive but I've never had any luck with it for anything. Either I'm not spraying both sides well enough or I'm not letting them get tacky enough before mating them or something, meh. Anyhow, so the carb cleaner did little to remove the glue, but it did melt the dash and I got rid of most of that pesky pattering on it that I was wondering how I was going to remake as I'd sanded a great deal of it off filling and repairing the cracks, front still had patterning but the top was a hodgepodge of filler and pattern. So I grabbed the DA, slapped some 80 grit on it and went to town. Took a while but I got it cleaned up fairly well. Right now I'm working on refilling any cracks, new cracks, old cracks, getting as smooth and uniform of a surface as I can. Now guess what is next? Bedliner.
James Bond shifted down into third gear, drifted the Saab 900 Turbo into a tight left-hand turn, clinging to the grass shoulder, then put a fraction more power to bring the car out of the bend. |
| Sponsored Links | ||
Advertisement | ||
My dash has a formed top on it which looks so close to the original it had me fooled when I bought my car. Makes me wonder if they are still around to be purchased somewhere.
My dash was attacked. I can't tell if it was a nauga or a troll. Maybe it was a fight between a troll and a nauga. Do nauga's eat trolls? ![]() Anyhow, its coming along, I've discovered the spray on bedliner will show all the cracks and defects beneath, it gets better the more you put on, but I'm all out and thinking perhaps I should have used the roll on. But meh, its drying, it will be interesting to see how it turns out. I also took my instrument pannel out, took it apart, replaced the tach with one out of another car, I now have a working instrument pannel again, well, at least the tach works, I haven't tried the lighting. Here's me with the other cars speedometer pegged out on the highway the other day. ![]() Man we were really flying along.
HA thats great, really had me lookin at that last pic till i looked closer at the dial....On a side note hit an honest 105-110 the other day behind a bunch of mustangs on I-95
All done. It isn't the best job, like usual I ran out of time and the car hastely reassembled and put back into service.
I used the spray cans of bedliner. If I had to do it again I think I would use the canned roll on, at least for the first coat/s to build up dept and cover any defects. The spray on leaves a nice finish, provided it doesn't build up on your finger tip and splatter, but since its thinner in consistancy, it shows any cracks or defects below. The before pic, you could see though it in places, this was back before even the naughagyde repair attempt. ![]() This is after the first coat. You can see where the cracks and some of the filled spots are, the whole dash was horribly warped and basically falling apart. Its starting to look a little better though. ![]() ![]() I didn't take any pics out of the car after I had all the coats on it, I put two cans worth on it it, probably should have put one more. From above. ![]() ![]() There is dust on it here in this picture, and no, my piller covers dont' really look that bad in real life.
One last pic, this shows the finish and texture well.
![]() As I said, if I were to do this again I would use the roll on bedliner for the first coat or two as its thicker and would cover defects better, then use the spray on to finish it off once you had a uniform surface to work with. It looks better than it did before though, so for the time being I'm more or less happy with it. I wouldn't say it looked great, or even good, but it does look alright and a lot better than it did. Yes, I know, I have a dirty car.
Us lot in the UK tend to think you guys have it easy with all that sunshine and warm weather - we don't see sun damage anywhere *NEAR* that bad. My '90 has one small crack from the driver's side speaker/vent to the glass.
Adrian Soon to be living life on the road in an old VW http://WhereverTheRoadGoes.com |
So, how about an update on how it's holding up? I'm thinking about giving this a whirl. Can you tell us exactly what the product you used is? Is there a certain color?
It looks great to my eyes, btw, though I'd like to keep my dash indentation.
![]() Black. Poorly. After a few days in the sun it developed little bubbles in places, I suppose its from little air pockets. Also, it has developed hairline cracks where the original fault lines were. Appearently the dash swells and constricts enough heating and cooling that the bedliner could't take the strain so it cracked in places. It still looks a lot better than it did, and I think with a better surface to adhere and a better quality bedliner it would work fine. I don't think it liked the bondo much though. I still think the roll on or actual real rhino liner type would work better. This stuff was the spray can "spray on" bedliner stuff, it really isn't much better than a tough paint. I think something like this would work better too, it seems to be thicker and tougher.
Thanks for the info. Seems that Rhino has a variety of colors these days - and they offer a UV resistant option. I'm thinking about giving it a whirl soon. I'd fill in the cracks with modelling putty or something first, then sand it down... and spray it with a primer or adhesion promoter first. If I do it, I'll post the results.
I like the job you did on the dash with the bedliner. looks great! im trying a few things myself to try and keep it looking as original as possible.
WHATEVER ...
Bet they dont have trolls v the naugahides at the battle of the o k Ke SAAB ... Ot that other classic Four weddings and a Wurthers... |
On the road: 90 c900T16 cabriolet - red 91 c900spg - red 79 Porsche 911SC - red Projects: 92 c900s 4dr - blue (on the backburner) RIP: 93' c900s (drunk driver hit it) 90' c900s (deer found it attractive) 89' c900T (Friend crashed it) 88' c900T (parted) 87' c900T (parted) 89' c900s (parted) My Bands Myspace Facebook Me |
| Sponsored Links | |
Advertisement | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
