2001 9-3 Grinding into reverse - SaabCentral Forums
Old 10-09-07
ajohns ajohns is offline
New Member
Default 2001 9-3 Grinding into reverse
Hello,
I have a manual transmission, 2001, 9-3. Every once in a while, about 40% of the time, when I put the gear selector in R, a terrible grinding sound can be heard.
I've noticed that when it is reluctant to go into R, I can't even get the gear selector into 5th at all. Also, putting it through 1-4 for a while seems to make the grinding go away.
What is causing this grinding and how should I fix it?
Thanks
Old 10-09-07
SAABVICIOUS SAABVICIOUS is offline
My Saabs: 2002 gray viggen convertible
my car does the same thing.. i also shift around if it resists when going into reverse and it works. from what i've read, thats the cheapest route..
Old 10-09-07
New Member
Is this because the reverse gear is not synchronised?
Old 10-09-07
Tweek's Turbos Tweek's Turbos is offline
My Saabs: 07 9-5 Combi, 99 9-3 Viggen, 85 900 SPG
A mechanic I will refer to as "SaabNazi" told me to always select a forward gear to align the syncros. ALWAYS.
Now your concern sounds like whats going on with my new 9-3 gearbox. Only 54k miles on the thing. I have been looking into this:
http://www.genuinesaab.com/psi/files...ans-update.htm
Old 10-09-07
New Member
What does aligning the synchros entail? Leaving it in a foward gear briefly before sticking it in reverse?
Old 10-09-07
AML93 AML93 is offline
My Saabs: 1999 9-3 SE
Yeah I have the same problem some times, I just shift through the cycle 1-5, then I put in reverse and that seems to work for me. I had the same trouble with my grand-am, which was manual trans. and I did the same thing when it was being a pain.
Old 10-09-07
saabSean's Avatar
saabSean saabSean is offline
My Saabs: 2002 9-3 SE Convertible
This is my remedy as well... select 1st gear, then select reverse. It does SVCK out loud when I forget to do this and get the awful crunch.
Sean
2002 9
3 SE Convertible | Red/Beige/Black | 5-speed
"I be SAAB'n, mon."
