| Saab 9-3 SS, Combi & Convertible Performance, Mods & Tuning Covers Tuning & Performance modifications for the Saab 9-3 Sports Saloon/Sedan, Combi & Convertible |
I'm looking to install a BOV on my saab 9-3 and was wondering which ones are good. i'm looking for one that just has a nice sqeak for a clan sound. and also i was wondering where to buy a block off plate and then the adapter to tap into the downpipe for install.
Thanks Alexander
Black 06 Saab Aero V6 VTuner Stage 0 BSR Intake And extras |
| Sponsored Links | ||
Advertisement | ||
Last i heard you couldn't put a BOV on a 9-3, atleast in the US, only BPVs
Why would you put a blow off valve on your downpipe..
well the setup looks like the same when i had a srt-4 before i blew it up. you put a block off plate on where the stock bov is because any aftermarket one will never fit where it is and then tap into the downpipe. thats exactly how i did it before so thats y im saying
Looks like another dude bought before doing his homework... The Trionic Engine management does not get along with BOV's...in the last couple of years only one guy has gotten one to work. And not on a US spec car.
Do a search on BOV and ByPass Valve...there is plenty to read. And if you want to do any major engine Mods you'll finf your choices limited with a 93SS. Oh, and last I heard, BOV's are installed way before the Downpipe,,,,, Last edited by JonV; 09-09-07 at 06:43 PM. |
well thanks for the info but i didn't buy the car to mod up and make a race car. thought it be cool to have a bov on the car. but anyways thanks for the info
If your just looking for the Bypass valve sound, you've got a couple of Options...an aftermarket Drop In Air Filter (ITG,JR) or a High Flow Intake like BSR's Optiflow or Simota's Aeroform II have good results...IMO stay away from the K&N POS, you have to Mod it to keep from throwing CEL's.
The downpipe is the part of the exhaust immediately after the turbo, so it has nothing to do with a BOV.... Also.... Trionic 7 and 8 are both air-mass metering engine management systems, so they won't work correctly if air escapes out of the system as with a BOV. You can upgrade your recirculating bypass valve but that won't do any good unless you upgrade a lot of other things first... |
just get an intake.. it sounds cooler and bov suck in out cars they dont even work.
"...stay away from the K&N POS, you have to Mod it to keep from throwing CEL's."
Please explain - CELs? I put a K&N filter in, along with a cat-back and BSR PPC and have had no fault codes, etc. |
Whether or not you get problems (CEL's in particular) has a lot to do with how you put K&N's intake parts on your Saab. Messing with an intake on a MAF-metered car is like messing with your eyeglass prescription. You may like your friend's designer frames, but if you trade glasses you won't see as well, because everyone knows it's the lenses that are the most important part. You may see well enough to get by, but it won't be 20/20. And in a lot of cases your vision will simply be worse with the switch. Your stock intake is similarly matched to your engine through something called a MAF transfer function. If you change the intake, you should change the MAF transfer function, which is software in the ECM. This service is not yet available for our cars. Whether or not you get a CEL with your intake mod has to do with how badly you screw up the fuel trim. Because of how precisely the stock intake is matched to the car, almost any intake mod can cause problems. Really it's just a matter of degree. You can learn a lot about this fast. Just google "maf transfer function." Here, I saved you the trouble: http://www.google.com/search?hl=en&q...=Google+Search |
I have a droP-in K&N filter. No problems. Unless your refering to the Intake Kit K&N sells??
Megan Racing Springs |
yes the 57i or some bologna
Please explain. thx |
didnt you get the bov working? |
(The Turbo X likes to pop occasionally on first-second shifts, just the way it came from factory, no flames tho I wager.)
Transport: '08 Saab 9-3 Turbo X '03 Yamaha YZF-R6 Turbo (yes, turbocharged.) |
Svenska Aeroplan Aktie Bologet |
sounds sweet, sombody got it to work! http://www.youtube.com/watch?v=GQHxliWoxGY
| Sponsored Links | |
Advertisement | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
