Vibration at highway speeds, Please Help! - SaabCentral Forums
Old 5th September 2007
silver02aero silver02aero is offline
My Saabs: 2002 Saab 9-5 Aero
Default Vibration at highway speeds, Please Help!
Hi guys,
I am having the hardest time trying to figure out what is causing my vibrations while driving on the highway. I recently had new tires put on the car, mounted and balanced. I brought my car to the saab dealership and had them do a four-wheel alignment, $130. But my steering wheel still vibrates and shakes over 55 mph.
Note: My left front rim has some nice chunks taken out of it as well as some curb rash from the previous driver. Is it possible that whatever this person did to cause that could have possibly done something to the steering/suspension that is causing my problem? (Rotating the tires does not change vibration though)
I am also getting some very strange tire wear which should not happen after balancing and a 4 wheel alignment. My tires are scalloping/cupping on the outer edge. If you rub your hand over the tire from front to back it is like rubbing a fish against the scales.
Any help would be great. This is such an annoying thing and I have done everything I know to try and fix it to no avail.
MacNoob's Avatar
MacNoob MacNoob is offline
My Saabs: 01 9-5 Wagon (RIP); 05 9-5 Aero (gone)
Maybe that rim is bent?
If I put that wheel on the back it does not make a difference with the vibration. The shaking seems to be coming from the front end. I thought that maybe the force hitting the wheel bent/broke some part of the front suspension/ steering which has cause the car to be permenently out of alignment but im not sure.
I remember reading a thread a while back about some other person who had a vibration between 70-75 mph, which I notice too, and he replaced something other than doing an alignment. He said that it made it go away. I can't find that thread though and a cant remember what he changed. Perhaps it was a bushing or something.
Wulf
Guest
Posts: n/a
It sounds like it could be bad shock absorbers. Check to see if they are leaking or have them tested at the dealer or other place. I checked the warranty record for my car and shock replacement is showing up twice on there.
BenP BenP is offline
My Saabs: 2000 9-5 SE Wagon, 2000 9-5 Aero Wagon
I agree with Wulf, check the front struts! How any miles are on your car?
A good alignment or tire shop should have inspected your suspension for wear prior to doing a 4 wheel alignment. How many miles have you put on it since you had the alignment done? Most shops give some kind of warranty on their alignments but it may not be much (30-90 days) so I would take it back to the dealer first.
Cupping and abnormal tire wear is a good sign that your struts are toast.
In the short time that I've owned my '00 9-5 SE Wagon I have noticed they are very sensitive to wheel balancing. I replaced my suspension with the Aero Suspension at 108,000 miles and the new struts cured about 90% of my wheel vibration at speed. It was vibrating pretty harshly from 70-74mph and now I only get a minor rumble.
BenP
Atlanta, Ga
I just replaced the entire suspension recently with new struts and eibach springs. Then I had the car aligned. I had the vibration before and after the suspension change so I dont think that is the problem.
There was nothing wrong with the old parts either. I simply wanted to enhance the looks of the car by lowering it an inch or so. Also the tire wear issue was happening with the old tires as well. I did this change maybe 5,000 miles ago and my tires are already looking like the old ones. And this is all after a 4 wheel alignment. The saab dealer did not say anything about my suspension components when they did the alignment. When I picked it up they just said, "yup it was out of alignment so that should be better." So I don't know what to do.
I suppose I could bring it somewhere to have them check the balance on the tires. I had toyo proxes put on at Town Fair Tire and the guys who did it seemed like complete idiots, in fact when I went they put a completely different size tire on one side of my car!
Do you think I should go have someone check the balancing?
Chris 9-5's Avatar
Saab Sage!
My Saabs: .
Erm....................yes
If the car has been properly aligned then the suspension etc should have been looked over - the only item seemingly staying the same with upgrades etc here is the wheel /tires combo.
I am going to bring my car to a local shop that I found doeas the raod force balancing and straighttrack alignment and have them take a look at it. I geuss all balancing machines are not always correct and this new technology appears to be the best.
Thanks guys for all your help! I'll let you know how it turns out
Chris 9-5's Avatar
Saab Sage!
My Saabs: .
Please do and good luck
Wulf
Guest
Posts: n/a
Balancing machines that are not calibrated properly and employees operating the machines are probably the main cause for problems.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
