How do I get it off? I've been trying for an hour and practically ruined it.
| Sponsored Links | ||
Advertisement | ||
Do you have to remove it? Or, are you trying to open it? Either way it should be lefty- loosy, just different sized tools.
I got it but I'm still having problems. I'm leaking antifreeze and it loses antifreeze quickly after I fill the container up. I've been told it's a water pump issue. How hard is it to do that repair and where is the water pump? Also it looks like where the transmission is (I think), is where its leaking. It's in the middle.
why do you need to use the drain plug? is it leaking.
if you cant undo it just drain the system by looseing the bottom rad hose using the jubilee clip. The water pump is belt driven on the back of your engine (near the bulkhead), kinda above the crank pulley and across from the alternator. |
The water pump is not too horrible to replace. It's in the middle of the back of the engine bay(wich is actually the front of the engine
if you are seeing the coolant leaking off the transmission guard, where it is dripping to the ground may be misleading. is the coolant dripping off the bottom of the transmission? the front or rear? on many cars, the turbo is both water and oil cooled. one of the water coolant lines is run off the bottom/front of the turbo and across the front of the transmission (by front, i am referring to the front of the car). the is tapped into the lower radiator hose, which is where it may well be leaking. if the leak is dripping off the back of the engine, more between the wheels than at the front, then your leak might well be a shot water pump. |
Thank you for clarificating that (yer backwards is on frontwards.
Run the car until the engine's properly warmed up. Then, with the engine still running, pop the hood and look for steam. That'll likely be your leak (there may not be much steam if the leak is slow). For the water pump, there's a weep hole tucked in under the pulley. You would be able to see it with a hand mirror (engine OFF for this test!).
When I replaced my water pump, I just unbolted the pump and allowed the coolant to drain out. It was mostly water at that stage 'cos I had to wait for the pump to arrive so I was just topping up with water. It only took about 2 litres to fill it up again. |
| Sponsored Links | |
Advertisement | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
