Ok, so where's the OBD-II plug on my SAAB? - SaabCentral Forums
Old 21-08-07
zenbeer's Avatar
zenbeer zenbeer is offline
My Saabs: 1998 SAAB 900-S
Default Ok, so where's the OBD-II plug on my SAAB?
Ok, I give up. Where's the outlet to plug my OBD-II sensor in my 1998 900-S? I've been staring at the engine like an idiot the last 20 mins.
-zen
Old 21-08-07
zenbeer's Avatar
never mind. Under the dash (doh!)
http://www.obd-2.com/dlcnet.html
"1998 Saab 900, 9000 connector is positioned on the underside of the instrument panel directly under the steering column (or approximately 150mm left or right of the steering column). with a cover."
Old 21-08-07
chcita's Avatar
chcita chcita is offline
My Saabs: GM 900SE 2.0T convertible
You have to be able to reach this connector from drivers seat, and I guess thats located in area under steering wheel...its definetly there, I saw it during change of clutch cable...
Old 21-08-07
chcita's Avatar
Youre faster man
Old 21-08-07
zenbeer's Avatar
Yeah I'm used to seeing them under the hood on some U.S. Cars.
So my error message is: PO133... O2 sensor CKT Slow Response (Bank 1 Sensor 1).
Hmm.
Is that the O2 sensor on the Cat.? I cleared the error. I wanted to take it through inspection today, but in my state a "check engine" light is a sure-fire failure. The guy I bought it from said the O2 sensor might need changing.
-zen
