Trans slipping from first to second - SaabCentral Forums
Old 19th August 2007
spg1 spg1 is offline
My Saabs: 2008 Aero 95
Default Trans slipping from first to second
Greetings,
Here I am again helping someone out with there 2003 aero 95. The problem is with the transmision from first to second only. It seems to be draging or just taking its time shifting from time to time. It doesn't do this all the time, maybe a couple of times a week and thats it. Could this be just dirt in a valve and it really just needs and oil change?
Also what kind of oil should he be using? Before I forget it is an automatic.
Any help would be great. Thanks,
Dennis
blinktude's Avatar
blinktude blinktude is offline
My Saabs: '03 9-5 Aero, '02 Trailblazer
assuming you have an automatic, my car has similar problem.
changing from 1st to 2nd is abrupt or rough when throttle is very gentle. when pedal is hard pressed, its smooth.
Old 20th August 2007
The trans is an automatic, did you ever find out what was up with yours?
Any other ideas, anybody? is this a very uncommon thing?
Old 21st August 2007
Acording to what I am reading in this work shop with this being an 03 this is a "5 speed automatic"? and I should be running Dextron III?
Since there has been only one responce to this, is it safe to say that this is a problem that is uncommon?
Ok, I went back and found that I made a mistake. So the 03 automatic takes "3309"? and is there a brand that I should be using?
Old 24th August 2007
Im sure hope someone can help me out with this. This is my last time to "Bump" sorry! Im sure my friend isn't the only one that has had this problem. Has anyone figured it out? It would just be great that We can help him out! Thanks,
Dennis
Old 25th August 2007
Kermit's Avatar
Kermit Kermit is offline
Saabista
My Saabs: 04 9-5 Vector 2.2Tid
Mobil do a type 3309 tranny fluid as does Toyota who call it type IV i believe. The 3rd option is go to a GM dealership and pick up the OE 3309.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
