Anyone tried them?
http://www.pulstarplug.com/ Apparently they do R&D here (Albuquerque). I was in fastener shop late yesterday getting a few nuts & bolts... guy in front of me was getting hardware as part of some plug testing machinery he was building for them. Sounds kind'a interesting. I'm in early stages of getting my head around MS (eg: improved ignition systems), and this conversation caught my attention as possible incremental ignition upgrade just by replacing plugs. From their web page: Quote:
Thanks. |
| Sponsored Links | ||
Advertisement | ||
That sounds great and all. But for our cars, nothing seems to work like the bog standard NGK plugs the cars were designed to run on. Which is great, because they are about $15 a set!
I've also read a lot about improved mileage/performace from faster/more precise timing/higher intensity spark ignition. Seems to me these Pulstars are different than standard plug alternatives (Champion/Bosch etc.)... eg. they provide some of what these ignition systems add but I assume they don't improve Spark timing as much, however. Quote:
In the olden days of points&condenser some of their claims may hold water. In those days there were kits that provided a capacitor discharge that was in fact a pulse. It was used on the primary side of the ignition system and provided the benefits claimed for these plugs. The Pulstar plugs seem to put the capacitor inside the plug's insulator operating on the secondary voltage instead of the primary.
It's possible that they would improve performance slightly if you had an old-fashioned ignition system although I would prefer the older, primary side, capacitive discharge. Their unstated assumption is that there is some sort of inefficiency with stock systems. Their claim of "unburnt" fuel is easily refuted with an exhaust gas analyser. I doubt their system could provide any advantage over any modern electronic ignition system that is, necessarily, capacitor discharge with electronic trigger. But it's not my $100 and they offer a no-questions-asked, money back guaranty; why not experiment? I would,however, be willing to bet on the results.
Corporations are people! If you prick them, do they not bleed? If you tickle them, do they not laugh? If you poison them, do they not die? |
I get mine for about $4-$5 a set.
James Bond shifted down into third gear, drifted the Saab 900 Turbo into a tight left-hand turn, clinging to the grass shoulder, then put a fraction more power to bring the car out of the bend. |
Thanks for comments Jim... always appreciate your imput.
Are you saying stock LH (xxx) ignition already provides what these things claim to do? Quote:
Offer them your car as a chance to really prove their plugs - as we're a hard bunch to convince that anything but the original plugs work best.
At no cost to you, of course, including proper dyno runs etc.
Photo Gallery |
As they say in their ad copy, voltage builds up, first appearing as ionization, until there is enough to jump the air gap in the plug. Jumping that gap gets harder as temperature and pressure increase. In the Direct Ignition system used in 9000s, the ionization is used to measure potential for detonation in place of the APC knock sensing system. Also, as they say, this takes place in a thousandth, if not millionth, of a second time period. After that their story starts to break down. Under compression, it usually takes about 5000-7000 volts to jump the gap on a good clean plug. If the conditions are less than ideal, such as a large gap on a dirty plug, it can take 15,000-17,000 volts to jump the gap (that's when your old wires start to leak voltage). In old ignition systems it took a long time (by electronic standards) to build up that much voltage to overcome difficulties. An old points&condenser system was usually limited to around 25,000 volts and struggled to reach that. Capacitors overcome the problem of slow buildup of voltage by holding back electrons (literally) and releasing them in a burst. This sounds like the claim they make. Using capacitors in such a system will produce the effects they claim. A modern system is already using capacitor discharge, either in the primary or, as in the case of DI systems, sometimes secondary systems. The discharge is timed by an electronic trigger. In the case of Hall Effect transmitters, it is a digital (square wave) signal that is instantaneous (for our purposes) and perfectly timed if you use a crank sensor (very well timed with a distributor mounted Hall Effect generator). This signal can be easily manipulated through the EZK box if called for. So your modern SAAB system is timed nearly perfectly; the timing can't be improved with spark plugs. It can also build up 50,000 volts instantly if that's what the plug needs to fire (good clean plugs will still fire at around 5000 volts). Resistor plugs artificially hold back the voltage until their resistance is overcome, that's why they require, and fire at, higher voltages. I just don't see what Pulstar is bringing to the game when you're starting with such a wonderful system....but I don't know everything, the proof is in the pudding, I'm willing to be proved wrong. I'd just like to bet on the outcome of real-life testing. Sorry for the long-winded response.
Corporations are people! If you prick them, do they not bleed? If you tickle them, do they not laugh? If you poison them, do they not die? Last edited by Jim Mesthene; 17-08-07 at 11:30 AM. |
But for me, a set of NGK plugs costs $34 PLUS SHIPPING! Just to add, cap and rotor are about $10 each, wires a good bit more. |
Once you have a high voltage leak it leaves a carbon path. The spark that leaked out of your wires because it couldn't jump the spark plug gap, burnt a path through the wires' insulation. Now you have 7mm worth of insulation on your wires with a little path of carbon burnt in. The next time voltage builds up, it finds that carbon path, follows it, and makes it wider. There's no way to eliminate the carbon path embedded in the wire's insulation. If you replace your plugs regularly, you eliminate the buildup of voltage that burns the first carbon path, so your secondary ignition parts (cap, rotor, wires) don't fail. Cap and rotor could last a lifetime if it were not for the minor erosion from normal sparking, and wear on the distributor contact (the springy thing). Wires (Bougicord) suffer a little ozone and heat deterioration, but should last 7-10 years. If you let the plugs deteriorate until the insulation on the other components is compromised, you need to replace the lot even if they're relatively new.
PfS want damn near Ł5/plug for NGKs for a 16v turbo, whereas German & Swedish want just over a quid each for Bosch. Are the NGKs *really* that much better? If they are, then I'll get the NGKs. If not...
Adrian Soon to be living life on the road in an old VW http://WhereverTheRoadGoes.com |
So, if this hasn't solved your problem, you've eliminated some possible causes, but its a much cheaper mistake to have replaced perfectly good plugs if they only cost $5-10. |
RE $15 plugs, I was just sort of pulling a medium ballbark figure out me butt. I think I pay less too.
The only real bottle neck to performance for our engines is getting enough air through them and out the other side. Plenty of fuel, plenty of spark. Oh yeah, and once you ramp up the power to the nth degree the tranny implodes anyway. Most of us would be much better off taking what we have, mildly massaging it and the driving the hell out of it. I always assume that people looking for massive HP improvements have driving skill deficiencies |
Here's what their rep, Lou Camilli, said in response to my questions: Quote:
It seems that the Puslestar person says "ignite". How is this different than a "regular" plug. Flame from a single point is still a single point of flame
Wonder how they work when they are -40°F. pierre |
I'm particularly intrigued because of research I read a couple years ago having to do w/ignition for gas discharge lasers. A very fast, hi-wattage ignition was the difference in success w/some of the military applications they were developing at labs here. I had friends working on that... very interesting stuff. It at least seems plausible to me. |
Yep I understand what you say. Sometimes a bigger hammer can make a bigger boom when striking something.
pierre |
There isn't really any way to increase the "amount burned" via sparkplug design. Most of the unburned gas in the engine is gasoline that has been absorbed by the minute thin oil film on the cylinder walls. You can't burn it, all you can do is make the oil film thinner (more or less) which requires a total engine redesign
One megawatt of power coupled to the fuel charge? More precisely relative to crank angle cycle-to-cycle? Like I said, I'd like a chance to bet on the outcome of a test.
Corporations are people! If you prick them, do they not bleed? If you tickle them, do they not laugh? If you poison them, do they not die? Last edited by Jim Mesthene; 17-08-07 at 10:22 PM. |
| Sponsored Links | |
Advertisement | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
