Cold Start Sputter - No Boost - SaabCentral Forums
Old 15th August 2007
Mag-X's Avatar
Mag-X Mag-X is offline
My Saabs: 2010 Saab 9-3 2.0T
Default Cold Start Sputter - No Boost
I did a search, but using the words "cold start" brings up almost every thread in the C900 section. I couldn't find one with my exact problem(s).
Starting the motor from a cold start results in one of two scenarios.
Scenario A)
1) Turn the key once: cranks and cranks, but doesn't fire.
2) Turn the key a second time, and it cranks and sputters and shakes, but doesn't actually start
3) Turn three it fires right up, but I cannot touch the gas pedal for a few minutes, or it will stall.
4) Starts running fine, but no boost
Scenario B)
1) Starts up first try, works great, but check engine light comes on.
2) No boost!
Then about 20 minutes later the boost just comes back.
sudo chown -R us ./base
grif900's Avatar
grif900 grif900 is offline
My Saabs: 1988 900 SPG
Senario A, leads me to suspect the amm.
senario B, suggests a wiring or connector issue(intermittenet problem). Or perhaps a failing amm(though I've never had one die quite like that) is possible. The amm does control the apc.
c900's Avatar
c900 c900 is offline
My Saabs: 81 8V 900T, 91 2.1 900i, 90 9k 2.0 Carly
Scenario A)
Scenario B)
2) No boost!
Is this on an 8V or a 16V car? I've found that on my 8V cars, esp. the older few with the fully-pressurised tank and no pre-pump, the engine(s) start but revs drop right down for a few seconds after letting go of the key, then come back up to normal, and I've determined that's just because of the fuel pressure still coming up as the pump pressurises the tank and starts to push fuel through the lines to the fuel distributor.
In 16V cars I wouldn't expect this sort of thing to happen, or in the 85+ 8V cars, since they all have the double-pump setup, however my theory could be off-track for your problem.
When I first got my 81 turbo car (8V non-apc) it had the wrong fuel pump relay. Instead of the special version with the extra terminal-50 connection, it had the version used in the non-turbo cars. I changed that for the right version (salvaged from the 83 turbo that I'm stripping [took more stuff off it yesterday!]), but it didn't seem to make a lot of difference.
Craig.
Craig Dewick - Somewhere in Oz -
Flux Capacitor Engineer at Mr Fusion - 1981 8V 900T, 1990 9k 2.0 Carlsson, 1992 2.1 900i - RIP Moose.Parts
Mag-X's Avatar
It's a '92 16Valve. I have noticed that it seems to happen more when the tank is full. I haven't been through that many tanks of gas though, so it could just be in my head.
Mars700 Mars700 is offline
Un hook the AMM and tell me what happens please..
Mag-X's Avatar
Sure thing. What is an AMM?
Air Mass Meter..
Old 16th August 2007
jglavin's Avatar
jglavin jglavin is offline
My Saabs: '13 Focus ST
I've heard a simple check of the AMM is to pull it off the filter, and have someone put the key in the run position... then look inside the AMM to see the small wire heating up and glowing orange...did the check on my 92 once and sure enough it glowed.
edit - I believe it only lights up for a sec and then goes out, so if you do the check look closely.
Mag-X's Avatar
OK. I'm at work right now. I'll go do that on my break.
How should it react with it disconnected?
silversaab96's Avatar
silversaab96 silversaab96 is offline
My Saabs: '75 96 - '90 9000T - '99 9-5 Wagon
You haven't been spray/steam cleaning the engine by any chance in the past day or so, or gone through big puddles? Had all these symptoms after cleaning the engine.. split or degraded rubber boots (on the back of the various electrical plugs) can do it, as can water in or around the top of the AMM.. just a thought....
All things are possible..except perhaps, skiing through a revolving door.
Mag-X's Avatar
Done. Runs like ****.
Mag-X's Avatar
No. There hasn't been a heavy rain in weeks.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
