| Saab 9-3 & NG900 Workshop Saab 9-3 & NG900 (1994 to 2002) Technical Forum |
Do the low speed fan must start when ac switch on? Because my fan only cycle normally but doesn't kick in with ac. So im getting warm air at all times even highway cruisin. I replaced the fan resistor already, all relays works, ac compressor runs. which electrical area i need to look at to get the fan run when ac power on or any other symptoms to check? please help..
ac was cold 2 months ago after charged up. but i never pay attention to fans, thank you |
| Sponsored Links | ||
Advertisement | ||
Have you tested the circuit to make sure the fan actually does work? Also does it run on after you have shut the car off?
In my 97 - I just did the relay, and now mine works...however I thought it was supposed to kick on when the ac was activated. It does not. It does run more when the ac is on though. Not sure if that is correct or not. All I can tell you is that for me - it does not kick on when the ac comes on - and my ac seems fine... |
yes, i've done the tests, both high/low speed fan work. low fan run after engine off for a min also. well, i had my ac on for about 10min, fan doesnt run more then normal. i shut it off because im afraid i'll do more damage to ac when it's not working properly. im thinking of getting check/recharge freon. is there a way to know if there's still alot of freon without using the gauge?
well, I got one of those hose kits with a can of 134a at the auto parts store. It has a built in guage. If you close off the can inlet side (without a can attached) then it works nicely as a guage to see if you need more coolant.
I would recomment the line type with the screw down shutoff valve rather than the kind that is more of a trigger. The kit is about $25-30 - and if you need 134a you then have some. There is all sorts of advice to go along with that - like be sure to attach the hose to the low pressure side - have the car running - and ac on max....the guage should then cycle at about 35 psi when the compressor is on (blue section of the guage) to then up into the yellow to red when the compressor cycles off (as the pressure then evens out in the system) - do not overcharge the system as then the ac will not work either...and you have to have the rpms up to about 2500 to actually charge effectively.... |
http://www.autoacforum.com/ The ICE controls the fans; but the Haynes shows nothing on the air conditioning. The fans must run when the AC is in use, BUT, they do not have to start up right away... All part of "high efficiency"..And, at speed, I doubt is the fans operate, even with the AC on....who knows
The earthworm '96 900S, Automatic Those who think in the past will have no future. 173K miles in the good ole USA |
ac cold now after a recharge. for the fan, it doesn't need to start when ac switch on.
thanks guys. |
| Sponsored Links | |
Advertisement | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
