How often do you change the tranny fluid?? - SaabCentral Forums
Old 13-08-07
fusionrx fusionrx is offline
My Saabs: 07 Honda Odyssey, 00 VW Passat 2.8LV6
Default How often do you change the tranny fluid??
Seen lots of conflicting reports about transmission fluid changing...
While my levels are fine in both my 9-5's (01 SE wagon 86k miles, 99 2.3L sedan 91K miles), I don't know if the tranny fluid has ever been changed... Is it something that needs to be done on a regular basis?
If I don't do it but keep the levels full, am I still ok?
Old 13-08-07
Chris 9-5's Avatar
Saab Sage!
My Saabs: .
I'm sure you are fine, but I would recommend a drain and refil every year of the ATF.
It only replaces about half the ATF fluid but does keep things fresh.
Old 13-08-07
MacNoob's Avatar
MacNoob MacNoob is offline
My Saabs: 01 9-5 Wagon (RIP); 05 9-5 Aero (gone)
With the age of your car, a complete replacement would be useful (12 qts changed 4 qts at a time with some driving in between). Then you can get to an annual change of the 4qts that is easy to drain.
